Stock tach/temp/gas tank/instrument lights not working in EF...
any quick ideas before I go hunting. This happened after hard driving in the canyons this morning...radio and dome lights do work though...
All fuses are good...
thanks
thanks
well, with your limited description. first thing I would check is the fuses (underhood & under dash), engine grounds & chasis grounds. next look for loose wires behind the under the dash leading into the instrument panel. it would be more helpful if you have a helms or haynes manual to look at the electrical wiring setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">well, with your limited description. first thing I would check is the fuses (underhood & under dash), engine grounds & chasis grounds. next look for loose wires behind the under the dash leading into the instrument panel. it would be more helpful if you have a helms or haynes manual to look at the electrical wiring setup.</TD></TR></TABLE>
thanks, not to much in the search feature, but one guy said he had the same thing happen and it was a broken wire when he removed his cluster
efking1985
Mar 9, 2007 06:04 PM
