B16a Spit and Sputter
Old Apr 3, 2004 | 12:38 PM
otto's Avatar
Default B16a Spit and Sputter
I cant seem to figure out the problem with my car. I've checked the compression. (205 205 205 205) I checked the plugs, wires, cap, and rotor. All in good working order. I checked the TPS and it registers fine. No codes are flashing on the computer. The problem is the car will sputter along at a cruising speed of say 40mph. At a lite throttle load it will start to spit and sputter like as if the engine dropped a cylinder. If you push the accelerator down just a little bit further the sputter will go away and power comes back. Any thoughts??
Old Apr 3, 2004 | 04:31 PM
spaceman's Avatar
Default Re: B16a Spit and Sputter (otto)
maybe the o2 sensors im not sure,check for any air/vacum leaks and then check out all your electrical wires and grounds..
Old Apr 3, 2004 | 04:57 PM
otto's Avatar
Default Re: B16a Spit and Sputter (spaceman)
I've ruled out all vacuum leaks. What electrical wires should I look for? How do I test them? What do I look for?
Old Apr 3, 2004 | 05:22 PM
Syner-G-Racing LLC's Avatar
from your discription it sounds like its within your ignition system...I know you said you checked your wires and plugs, but you may want to check you coils and module also...if thier fine then check the gap on your plugs
Old Apr 3, 2004 | 05:25 PM
otto's Avatar
Default Re: B16a Spit and Sputter (Syner-G-Racing)
I'll give it a shot. OH, and I checked the plugs all ready. Gaps are good and color is fine too.
Old Apr 3, 2004 | 05:28 PM
let me know if your module and ignition coil are good...ill do a little more thinking and see what i can figure out.
Old Apr 3, 2004 | 05:30 PM
otto's Avatar
I forgot!! I replace the distributer all ready trying to fix this problem some time ago.
Old Apr 3, 2004 | 05:40 PM
if the distributor is fine then call hondata and see if they can help you with an ecu problem.
Old Apr 3, 2004 | 05:42 PM
otto's Avatar
That's what I was afraid of. I think it's my ecu. How is hondata going to help?
Old Apr 3, 2004 | 05:49 PM
onePOINTsix's Avatar
hondata cant help, sounds like you have obd0, have you replaced your fuel filter? Sounds like it's not getting enough fuel, happened to me in our GTI... Good Luck
dcsports
Dec 7, 2008 06:54 PM
Speed_1
May 30, 2008 08:28 AM
axionm1k
Apr 2, 2008 06:58 AM
13link EG
Jul 1, 2006 04:18 PM
MADEINIRAQ
Jul 26, 2002 08:55 AM
