converting a cable tranny to hydrolic??
Old Apr 2, 2004 | 08:47 PM
Jerod's Avatar
Default converting a cable tranny to hydrolic??
I was thinking earlier would it be hard to actually convert a b16 cable tranny to hydrolic? All you would need is the bellhousing from the hydrolic b16 tranny right? Me and my friend are thinking of doing this. Gimme info........
Old Apr 3, 2004 | 05:01 AM
doublejz's Avatar
Default Re: converting a cable tranny to hydrolic?? (Jerod)
hrm, good luck with that. im pretty sure some of the stuff won't be able to switch over, but im not completely sure.
here this will make your life much easier buy a hydro tranny and get this
Old Apr 3, 2004 | 05:38 AM
Jerod's Avatar
Default Re: converting a cable tranny to hydrolic?? (doublejz)
I know about the kit. I can make it. it's not ****. I've already made one for a friend of mine. Just would rather keep it hydro.
Old Apr 3, 2004 | 05:54 AM
Sliced Beard's Avatar
the only transmission that i could fathom being able to be switched to a hydro case is either a YS1 LS tranny of a YS1 GSR tranny considering that you can use a ITR LSD in them and that they have the same input shaft diameter
Old Apr 3, 2004 | 05:56 AM
Default Re: converting a cable tranny to hydrolic?? (dirtyd463)
i personally have the hasport kit in my car and i have mixed feelings with it
i love the fact that i can use a GSR YS1 tranny in my Sol but i hate the way the clutch engages. it has a tendancy to be inconsistent in pedal feel
Old Apr 3, 2004 | 07:18 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerod &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking earlier would it be hard to actually convert a b16 cable tranny to hydrolic? All you would need is the bellhousing from the hydrolic b16 tranny right.</TD></TR></TABLE> nope. if the b16 cable trnny is a small spline tranny you cannot swap all of the internals over to the hydro case.
of course if you have a 92-93 GSR tranny with big spline goodness, its easy to swap to a hydro case.
Old Apr 3, 2004 | 07:40 AM
Jerod's Avatar
So it won't work but if i had a 92-93 gsr tranny i could make it hydrolic. this sucks
lakai_19
Oct 3, 2007 05:28 PM
ali_232
Apr 8, 2007 11:03 PM
type_one1
Oct 3, 2005 04:51 AM
arielmalespin
Feb 15, 2005 08:41 PM
tncivic-dvsb
Oct 30, 2003 07:29 PM
