How much whp gain with no cat?
Paragraph Alert
Have any of you guys messed around on the dyon to see how much hp can be gained by completely removing the exhaust from the header back? Might be going to the track this weekend and was thinking of unbolting my rear section. Thanks in advance.
With the following mods: intake through highbeam, Comptech foam filter, JDM Honda 4-1, Chris dyno'd at:
173 WHP with stock muffler, b-pipe and test pipe
174 WHP with stock b-pipe and test pipe
176 WHP with just the test pipe.
Torque figure was unchanged. Bring earplugs if you go ahead with the last setup.
*edit*changed description*edit*
[Modified by Bob#497, 11:21 PM 10/24/2001]
Here's another can of worms.
While Bob did see an increase I believe he did since the stock cat/exhaust is so restrictive due to the bottle necks. But I would say he could have picked up a little more with a tuned length tailpipe attached to the header. RStoR LOST 2-3whp when he went from a test pipe and full 2-1/2" exhaust to an open header.
Paragraph Alert
So if I'm going from stock Cat to no cat I should expect around 6whp gain or so? If going from test pipe to no cat nets 3 whp I would expect to gain alot more having the stock cat in place.
Cant compare me to having a CAT...cause in all those runs I didnt have one! I would expect going from FULL STOCK exhaust to NO exhaust..maybe 8-10WHP PEAK max.
OH_1fstgsr
12
Sep 5, 2010 02:22 PM
