Does The B Pipe Bottle Neck Make A Difference?
Old Jul 23, 2001 | 12:56 PM
SMSP's Avatar
Default Does The B Pipe Bottle Neck Make A Difference?
Yes, I installed a 2-1/2" ID x 2-3/8" OD B pipe adapter on Darth VadeR's ITR a couple of weeks ago. He has the Toda header with the Tanabe 60mm (2.36")exhaust and a CarSound 94006 cat. The Tanabe has a 2" OD x 2" long bottle neck right at the B pipe. Here is his before and after dyno runs. Now I believe the 174.9 peak HP run was made with some extra tuning. His first run on the dyno showed about a 4HP (172) peak gain with the adapter prior to tuning. Also, I want to point out that these runs were on different days.
http://foryourimports.com/uploads/hondatech/071401.jpg
Old Jul 23, 2001 | 01:04 PM
Chris's Avatar
Default Re: Does The B Pipe Bottle Neck Make A Difference? (SMSP)
Running a test pipe and stock exhaust, I removed the b-pipe and muffler and gained 4 WHP pretty much accross the whole band. This was on the same day about 5 min apart.
Old Jul 23, 2001 | 01:09 PM
Black SVT's Avatar
Default Re: Does The B Pipe Bottle Neck Make A Difference? (Chris)
Just wondering.What else was done to the car?
FBP_1171's Avatar
When I installed my JDM I noticed this. I have the same cat, and the reduction is pretty obviously a bottleneck. So I was thinking about getting a cat back or modifying the b-pipe to get rid of that reduction (which is there because the stock cat is a smaller diameter).
Good info
Old Jul 23, 2001 | 02:02 PM
HapaHaole's Avatar
Default Re: Does The B Pipe Bottle Neck Make A Difference? (FBP_1171)
the bottle neck promotes the cat working well. yes it created more back pressure for the cat. if you can get rid of it, do it, you may see a couple of ponies worth on the dyno. if you remove the caat however, thats a different story.
Old Jul 23, 2001 | 02:10 PM
Back in Black's Avatar
Rather OG
Default Re: Does The B Pipe Bottle Neck Make A Difference? (Dc2k-specR)
Dc2k-specR-
Here's the current setup-
Toda header
Tanabe Racing Medallion exhaust
SMSP bottleneck adapter
Apex-i V-afc (VTEC at 5200rpm)
AEM cai
Needless to say I am extremely excited with the recent plot and am very much anticipating further tuning with the Toda B valvetrain. I anticipate having the installation complete and semi-tuned by early September...
Thanks again to Dave (SMSP) for both the install and the opportunity to try the adapter out. I highly recommend him to anyone that's looking for advice on improving their car's flow
Old Jul 23, 2001 | 03:25 PM
FBP_1171's Avatar
Default Re: Does The B Pipe Bottle Neck Make A Difference? (Darth VadeR)
Keeping my cat. Need to pass smog...
Old Jul 23, 2001 | 03:34 PM
SMSP's Avatar
Darth VadeR is running the 94006 cat, so he'll pass smog.
YC Underground
10
May 10, 2012 02:00 PM
YC Underground
Feb 13, 2012 05:09 PM
OH_1fstgsr
12
Sep 5, 2010 02:22 PM
kornkid21792
Jul 14, 2009 09:26 AM
ActiveAero
Oct 24, 2001 10:20 PM
