ITR Motor Swap Into 92 LS
Old Oct 24, 2001 | 09:37 PM
SweetChin's Avatar
Default ITR Motor Swap Into 92 LS
hi guys...i might have access to a type r motor and trans for cheap and i was wondering how hard of a swap that would be in to my 92 ls..manual of course...was just curious about motor mounts,axels, the tranny options(hydrolic/cable), ecu and all the good stuff...i am either gonna do that and go turbo down the line or get another b18a/b motor and rebuild and go turbo
thanks
Old Oct 24, 2001 | 09:47 PM
MK Ultra's Avatar
Default Re: ITR Motor Swap Into 92 LS (SweetChin)
As for the B18C5 swap, probably the easiest way to deal with the tranny issues would be to slip the entire ITR gearset and differential into the LS case. The B18C5 will bolt right up to the B18A's tranny, which is good because the 3rd Gen trannies don't bolt straight into the 2nd Gen chassis. Doing this also gets you around the whole cable/hydro clutch issue.
Old Oct 25, 2001 | 08:33 PM
SweetChin's Avatar
Default Re: ITR Motor Swap Into 92 LS (MK Ultra)
ok i suppose i could just use the ls tranny...that keeps axels less complicated along with the cable/hydro issue....but will the ls tranny be able to hold the power...also does anybody know if i would have to get special motor mounts
Old Oct 25, 2001 | 09:23 PM
Halo's Avatar
Dam that's a good question, I want to know also
Old Oct 25, 2001 | 10:16 PM
Slain's Avatar
Default Re: ITR Motor Swap Into 92 LS (Halo)
if you can get the motor and find yourself a b17 tranny or a tranny off of jdm xsi integra.. easiest way IMO
_88EFhatch_
15
Jul 18, 2008 07:08 PM
sazdasl
Nov 20, 2006 03:36 PM
ProjectJDMIntegra
10
Jan 20, 2006 05:42 AM
JDM Vision
13
Aug 1, 2005 02:50 AM
Jdm_Rice_Monster
Jan 15, 2003 11:18 PM
