Leakdown test results!!!!!
Old Apr 2, 2004 | 01:32 PM
SleepyHF's Avatar
Default Leakdown test results!!!!!
I recently did a leakdown test on a mini me swap a6 block with z6 head, 180 all across the board except in cyl #2. and it oil smokes at idle...aslo the headgastket has been reused 3 times with a total of 100 miles on it...why is cyl 2 not getting 180. and why does it smoke when it idles??
Old Apr 2, 2004 | 05:00 PM
SleepyHF's Avatar
Default Re: Leakdown test results!!!!! (SleepyHF)
bump
Old Apr 2, 2004 | 05:07 PM
Lord Helmet's Avatar
possible reasons: bad headgasket(never reuse headgaskets imo), blown piston rings, etc... basically you need a rebuild.
Old Apr 2, 2004 | 08:36 PM
MrBui's Avatar
Default Re: Leakdown test results!!!!! (sleeperciv)
a leak down test is given in % i think you ran compression...a leak down test you put air pressure to each cylinder and not crank the car over with a gauge in the spark plug hole....
Old Apr 2, 2004 | 09:11 PM
igor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyHF &raquo;</TD></TR><TR><TD CLASS="quote">I recently did a leakdown test on a mini me swap a6 block with z6 head, 180 all across the board except in cyl #2. and it oil smokes at idle...aslo the headgastket has been reused 3 times with a total of 100 miles on it...why is cyl 2 not getting 180. and why does it smoke when it idles??</TD></TR></TABLE>
If you have re-used the head gasket three times, it is no wonder that the compression test shows up low on a cylinder.
try sticking a new head gasket in.
Old Apr 2, 2004 | 11:21 PM
iam7head's Avatar
Default Re: Leakdown test results!!!!! (igor)
or a nice nick in between would do that
uberEFtuner
Apr 11, 2014 06:11 PM
-HONDA-
Dec 19, 2006 10:58 PM
SOHC_MShue
Jun 29, 2005 06:05 PM
rasinhell
Feb 22, 2005 11:06 PM
