Q: Are there two D4 lights, while in Park position: steady and flashing? n/t
Old Apr 2, 2004 | 02:44 AM
diyer's Avatar
* B A N N E D *
Default Q: Are there two D4 lights, while in Park position: steady and flashing? n/t
Perhaps I should see if the D4 is any different when idling or not running, and get back to the board. Unless you already have an answer either way. It may not be flashing but just highlighted. Going to check today asap.
Thank you,
Diyer
Old Apr 2, 2004 | 05:30 AM
JimBlake's Avatar
Default Re: Q: Are there two D4 lights, while in Park position: steady and flashing? n/t (diyer)
If it's blinking, the tranny computer uses the D4 light kinda like it's own 'check-engine' light. You can pull codes the same way as as for CEL, but the D4 light will blink instead.
Old Apr 2, 2004 | 07:47 AM
diyer's Avatar
* B A N N E D *
Default Re: Q: Are there two D4 lights, while in Park position: steady and flashing? n/t (JimBlake)
Jim, is there a separate diagnostic socket for the tranny codes?
In other words, do I use the standard CEl OBD I socket or something else?
diyer
Old Apr 2, 2004 | 08:01 AM
JimBlake's Avatar
I always thought it was the same, don't know if any particular year they did it different. The only auto I own is the '98 & it hasn't screwed up (yet). When you jumper it you can even have the CEL, D4, & ABS light each blinking their own codes...
mphsprelude
Sep 21, 2009 01:43 PM
dc9turbo
Nov 18, 2004 09:52 AM
Siegfried
Mar 7, 2004 04:13 PM
mechanized
Nov 5, 2002 11:35 AM
