UH OH compression test result are bad news, and i'm still clueless....
Old Apr 1, 2004 | 09:02 PM
Ryan C's Avatar
Default UH OH compression test result are bad news, and i'm still clueless....
Boosted GS-R
running 10psi
Idle has a real stutter to it.
No oil in coolant or visa verse.
Not burning oil.
No smoke from tail pipe at WOT
just a crap *** idle and CRAPPY compression results.
CYL 1: 230
CYL 2: 225
CYL 3: 75
CYL 4: 180
Thinkin maybe ringlands
Blown HG, no idea what do you guys think?
Old Apr 1, 2004 | 09:11 PM
IloveNewt's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (Ryan C)
bent valve maybe....Leakdown time.
Old Apr 1, 2004 | 09:16 PM
Ryan C's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (MordecaiPSI)
i highly highly highly doubt its the valves.
but thanks for the suggestion.
back to the top either way
Old Apr 1, 2004 | 09:29 PM
TravSi's Avatar
dont highly highly doubt anything.....The world can burn at the flick of a switch, dont forget that....
Old Apr 1, 2004 | 11:00 PM
sporkcrx's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (TravSi)
bump, subscribing to this one.
Old Apr 1, 2004 | 11:36 PM
TeamCracka's Avatar
Try a leakdown test and see how much the results vary. That'll tell you if your ringlands are shot.
Old Apr 2, 2004 | 04:16 AM
fjt's Avatar
fjt
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (TeamCracka)
Does it iddles like if you had a big cam on it? very lopey?..If so then i think ur #3 piston is trashed.
Old Apr 2, 2004 | 05:17 AM
USDM 4G VTEC's Avatar
to loose that much compressiom u either have bent valves or blown rings
or headgasket blown between #3 & #4
if it idles like **** but runs kinda OK then u defenetly have bent valves
like someone said
just get the leakdown done
Old Apr 2, 2004 | 06:50 AM
Ryan C's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (USDM 4G VTEC)
you know i'd love to get a leakdown done, funny thing is know one around here does them! so how does one do a leakdown or what tools are needed and i'll grab em
Old Apr 2, 2004 | 06:59 AM
b18bturbo's Avatar
air compressor leak down tester and thats all you would need to do a leak down test. The testers you can get at most auto parts stores. or online.
Old Apr 2, 2004 | 07:08 AM
raene's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (b18bturbo)
Tavia makes a good leakdown tester, that's what I've got.
Old Apr 2, 2004 | 07:18 AM
Flr Power's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (raene)
Just put a teaspoon of oil in #3 cyl. If you get higher compression then you know it's piston related.
Old Apr 2, 2004 | 07:26 AM
Ryan C's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (coocoo32)
i'll be trying to grab a tester today i'll keep yall posted
Old Apr 2, 2004 | 09:30 AM
danl's Avatar
Banned
#3 usually detonates first, my vote is for cracked ringland/rings.
Old Apr 2, 2004 | 11:35 AM
RGAZ's Avatar
New User
Just take the head off and look. Don't waste time or money with theories.
The car runs like ****, just take it off. I am sure the problem will be obvious.
You have to fix it anyway.
What immortal time wasters.
R
Old Apr 2, 2004 | 01:14 PM
96-EJ6 B18C's Avatar
Default Re: UH OH compression test result are bad news, and i'm still clueless.... (RGAZ)
Bump I'm curious to see what happened.
vinuneuro
Apr 25, 2007 10:13 AM
iBrandon
Jul 31, 2006 08:03 AM
allmotorls95
Apr 24, 2003 04:37 PM
jdm169
Mar 7, 2003 09:28 AM
lazyguy
May 5, 2002 01:36 PM
