STR throttle body?
Old Apr 1, 2004 | 07:30 PM
turboman's Avatar
Default STR throttle body?
I can get a STR 70mm throttle body pretty cheap. Would I see any advantages with a 1.6 SOHC motor with 12lbs of boost?
I also plan on changing the downpipe to a 3inch pipe if that matters. Possibly also the exhaust manifold.
Old Apr 1, 2004 | 07:42 PM
TurboJesse
Guest
Posts: n/a
Default Re: STR throttle body? (turboman)
what are you running for fuel management? Your running the greddy kit correct? My neighboor was making 215whp (stock greddy kit and Hondata s100b) on a non vtec sohc. I would look into fuel management before you worred about throttle boddies etc (if you dont' already have it)
Old Apr 1, 2004 | 07:51 PM
turboman's Avatar
Default Re: STR throttle body? (Mpir3)
I have a hondata system. The car runs very well, although it's set a bit rich.(sometimes lets out a fart between shifts)
I still have the greddy kit with all the original pipes, manifold, turbo, and down pipe. The downpipe has broken several times and I just kept welding it back together
Old Apr 1, 2004 | 07:56 PM
Nid Styles's Avatar
I'd buy it, but wait until you get a bigger downpipe, and exhaust before you put it on. Otherwise it's pointless.
Old Apr 2, 2004 | 09:28 AM
turboman's Avatar
Default Re: STR throttle body? (Nid Styles)
Anyone else think this is good or bad?
I guess my biggest worry is that I only have my foot half way to the floor and I'm already at full power.
stoned_sol
Jul 7, 2005 03:07 AM
King-Kong
Jun 5, 2005 03:54 PM
