Knocking in front end????
Old Apr 1, 2004 | 05:56 PM
AgentJam's Avatar
Default Knocking in front end????
Ok just got my car pretty much done (everything, suspension/paint/brakes/rust removal, etc.).
Problem: When i go aroud turns at high rates of speed there is a knocking sound from the front end that happens repeatedly as if something rotating is banging with each turn. I've heard that axels "click" when going bad but this is more of a knocking that can be heard and felt. Happens when turning in either direction and like i said it only happens when going fast around a tight corner.
Problem 2: When decelerating from ~55-45mph my brakes shudder but only at those speeds. Before and after when breaking they are fine. I guess that rules out rotor warpage so what else is left to check? Feels like it's coming from drivers side.
Help highly appreciated
Vince
Old Apr 1, 2004 | 06:01 PM
erikiksaz1's Avatar
Default Re: Knocking in front end???? (AgentJam)
Problem 2: I was searching around a while ago about alignment problems, and i remember reading that braking might be a bit wobbly if your alignment is off.
It was somewhere in this link:
https://honda-tech.com/zerothread?id=734213
Old Apr 1, 2004 | 06:07 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
My car does the same and its the wheel bearings
getting them replaced on saturday
Old Apr 1, 2004 | 06:08 PM
AgentJam's Avatar
Default Re: Knocking in front end???? (erikiksaz1)
cool thanks, i did just get my car aligned at just tires but even after i got it back it still feels a little weird. I think i'm going to go to firestone and get the lifetime warranty.
Still doesn't solve problem 1!
Anybody else!?
Old Apr 1, 2004 | 06:09 PM
AgentJam's Avatar
Default Re: Knocking in front end???? (MR.RED'89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED89 &raquo;</TD></TR><TR><TD CLASS="quote">My car does the same and its the wheel bearings
Which thing?
Old Apr 1, 2004 | 06:11 PM
Bserieskllr's Avatar
Note the Just Tires part hehe...ne ways have you check the axle boots to make sure cause mine is really loud.
Old Apr 1, 2004 | 06:14 PM
AgentJam's Avatar
Default Re: (Bserieskllr)
last time i was under there (2 weeks ago?) the boots were fine. Is your axel bad? What does it sound like?
Vince
Old Apr 3, 2004 | 02:13 PM
well a clicking noise everytime you turn...for example if your pass. axle is bad then everytime you turn left you will here the noise....or a easy way to check is to turn you wheel all the way to one side and check the boots.
Old Apr 3, 2004 | 02:20 PM
lvbuckeye's Avatar
i had a similar problem, and it was the wheel bearings...
Old Apr 3, 2004 | 07:45 PM
AgentJam's Avatar
Default Re: (lvbuckeye)
boots are in pretty much perfect condition...it's not a clicking and it's not under normal turning. It's a loud repetative knocking under heavy cornering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvbuckeye &raquo;</TD></TR><TR><TD CLASS="quote">i had a similar problem, and it was the wheel bearings...</TD></TR></TABLE>
Which problem? The banging around turns? or the vibration at a certain RPM?
Thanks,
Vince
Old Apr 5, 2004 | 05:43 PM
AgentJam's Avatar
Default Re: (AgentJam)
Caman!
Would a CV joint do this? No?
When i search all i get is that people say a wheel bearing "whines" or "whirr's" when they make turns...
Mine is a repetative "thump-thump-thump-thump-thump" when i make a hard left turn, now i realize that it happens when i hit a bump in the road so anytime load is applied to my right tire.
Please and Thank You's!
Vince
Old Apr 5, 2004 | 07:48 PM
b18oldbodyhatch's Avatar
Problem 1 is probably and axle jack it up and check for cracked or rips in the dust boots.
Problem 2 your rims could be bent mine did it in my 90 civic si and whem i out some other ones i have lying around the garage it stoped it.
CJ
Old Apr 5, 2004 | 08:07 PM
AgentJam's Avatar
Default Re: Knocking in front end???? (b18oldbodyhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18oldbodyhatch &raquo;</TD></TR><TR><TD CLASS="quote"> Problem 1 is probably and axle jack it up and check for cracked or rips in the dust boots.
CJ
Cool, i checked my boots and they look in new condition...how do you check if an axel is bad?
Vince
Old Apr 9, 2004 | 12:02 PM
AgentJam's Avatar
would a bad tie rod end do something like this? I checked mine and they can be rotated at the ball joint end with one had but i dont feel any play...how about the steering rack? Would this only happen in one direction?
Vince
foxjaeger
Mar 12, 2009 09:31 AM
civic89si666
26
Feb 7, 2008 10:33 AM
honda_ef9
Apr 7, 2007 01:40 PM
satsilprelude
Aug 30, 2006 05:17 PM
