CHECK THIS OUT -- the cure for sloppy honda motor mounts
Old Oct 24, 2001 | 05:29 PM
speedworks's Avatar
Default CHECK THIS OUT -- the cure for sloppy honda motor mounts
go to a local autobody supply store that sells (Lord)Fusor products. ask for the
123 catalized seam sealer (about 30 dollars). remove the mounts you want to
be tighter (especially the rear), tape up one side,mix enough sealer to fill up
mount and pack it in (do this pretty quickly because it starts to set up within a few minutes). when finished let it dry about 2 hours before reinstalling. this will make the mounts stiff enough for drag racing but just soft enough so it will not vibrate
during daily driving.
Old Oct 25, 2001 | 05:03 AM
Reverend's Avatar
Default Re: CHECK THIS OUT -- the cure for sloppy honda motor mounts (speedworks)
Can anyone confirm this method?
Old Oct 25, 2001 | 06:04 AM
GGrahnVI's Avatar
New User
Default Re: CHECK THIS OUT -- the cure for sloppy honda motor mounts (Reverend)
Yes.
Or window weld. Or silicone. Old school hot rodder el cheapo trick.
Old Oct 25, 2001 | 08:09 AM
Jared's Avatar
Listen to the man, that **** works, kiss wheel hop goodbye.
Old Oct 25, 2001 | 10:09 AM
rtype11's Avatar
or for about forty bucks but the prothane inserts
Old Oct 25, 2001 | 05:57 PM
Jared's Avatar
Default Re: CHECK THIS OUT -- the cure for sloppy honda motor mounts (rtype11)
The prothane inserts can't compare to this trick.
Old Oct 25, 2001 | 08:45 PM
JFK78's Avatar
Default Re: CHECK THIS OUT -- the cure for sloppy honda motor mounts (Jared)
Any reason why you say it is better than the polyurethane inserts? I have the inserts, and they reduced wheelhop somewhat but didn't eliminate it. But damn, my car shakes, rattles, and buzzes really bad at idle, and is still a little buzzy once in motion.
Would filling the mounts with silicone be as effective at preventing the motor from moving around, while eliminating the transmission of vibrations into the car? If so I may consider doing that.
Old Oct 26, 2001 | 04:49 AM
speedworks's Avatar
Default Re: CHECK THIS OUT -- the cure for sloppy honda motor mounts (JFK78)
this is harder than silicone and will fill the entire void in the mount whereas the
motor mount inserts will not.
Old Oct 26, 2001 | 04:53 AM
JM Performance's Avatar
I dont know much about the mounts, so can you explain how to do this a little better? What do you mean by fill in the mounts and pack it in?
Old Oct 26, 2001 | 05:01 AM
rtype11's Avatar
I like your idea but even if it works to its full potential we need to be able to mount our motors like the domestics to a motor plate resulting in no movement at all, see if you can think up a way to mount a b-series so it doesnt move and is attached to the frame rails through a plate.
scabbs
Sep 17, 2007 09:57 AM
00000xxx
Oct 15, 2004 10:50 PM
gsr2jdm
Jul 13, 2004 07:49 PM
Cow
Mar 17, 2002 02:48 PM
Turbo EG6
Nov 30, 2001 06:43 PM
