cometic head gaskets???
Old Apr 1, 2004 | 01:57 PM
allmota1.8's Avatar
Default cometic head gaskets???
wanted to know if i can use a cometic head gasket. 81mm 0.40 thickness> on my car? b16a .25overbore ctr piston
Old Apr 1, 2004 | 05:33 PM
mmuller's Avatar
Mad Scientist
Default Re: cometic head gaskets??? (jkjb16a)
yeah, it will lower your compression to 11.5
Old Apr 1, 2004 | 06:05 PM
Sliced Beard's Avatar
Default Re: cometic head gaskets??? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it will lower your compression to 11.5</TD></TR></TABLE>
actually your compression will be 10.5:1
and with a stock head gasket you will be at 10.8:1
this is if you have a STOCK head (no milling) and stock block minus the .25 overbore
Old Apr 1, 2004 | 06:06 PM
Default Re: cometic head gaskets??? (dirtyd463)
this was my reference
Old Apr 1, 2004 | 08:17 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">
this is if you have a STOCK head (no milling) and stock block minus the .25 overbore</TD></TR></TABLE>
No, actually you are wrong, please do a search on compression height....
https://honda-tech.com/zerothread?id=717928
read that and you shall see the light.
pct's on a b16 actually comes out of the block .01
Old Apr 1, 2004 | 08:39 PM
yes they do
they also stick out .010" on a b17
i completely forgot about that until you mentioned it
ProjectBB6
Mar 13, 2008 09:24 AM
melovesboost
Feb 18, 2007 07:27 AM
Widebodys2k
Honda S2000
12
Apr 10, 2006 08:21 AM
prdtr15
Sep 25, 2003 03:45 PM
p1ccoloz
Apr 21, 2003 09:41 AM
