OEM SPARK PLUGS OR NGK
Old Apr 1, 2004 | 01:32 PM
mikestypeR
Guest
Posts: n/a
Default OEM SPARK PLUGS OR NGK
well its time to do the 60k maintenence stuff
so alot of people tell me to get the $15 per plug OEM plantinum one's
but i have heard that many use the $2 per plug NGK non platinum's
what do you guys think is best?
i know i will have to replace the ngk ones faster but thats no problem.
Old Apr 1, 2004 | 01:39 PM
B2FiNiTY's Avatar
Default Re: OEM SPARK PLUGS OR NGK (mikestypeR)
If you are down with replacing your plugs every oil change then get the regular $1.99 ones.
Otherwise the platinum ones last for about 30k.
Old Apr 1, 2004 | 01:45 PM
Opie's Avatar
I have NGK temp 7 iridium plugs. I like them , I guess. Can't tell any difference between them and the OEM plugs.
Mikestyper -->caps lock retarded!
Old Apr 1, 2004 | 01:46 PM
mikestypeR
Guest
Posts: n/a
Default Re: OEM SPARK PLUGS OR NGK (B2FiNiTY)
true... its just that 15 dollar price tag is a big one especially since i am broke as a joke .... ill do it we-todd-style and go with the 1.99 one's
Old Apr 1, 2004 | 01:47 PM
mikestypeR
Guest
Posts: n/a
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Mikestyper --&gt;caps lock retarded! </TD></TR></TABLE>
opie---&gt;******!
u rolling to atl meet opie
Old Apr 1, 2004 | 01:48 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeR &raquo;</TD></TR><TR><TD CLASS="quote">true... its just that 15 dollar price tag is a big one especially since i am broke as a joke .... ill do it we-todd-style and go with the 1.99 one's </TD></TR></TABLE>
if you want to save money. run platinum..
Old Apr 1, 2004 | 02:06 PM
RTW DC2R's Avatar
NGK Vpower plugs will be fine. non platinums, work just as good, if not better, than my stock plats and the current Iridium IX that Im running. Cheap too, $1.68 at my local advanced auto. Only downside is they probably dont last quite as long as the plats or iridiums. Just make sure you check them frequently.
Old Apr 1, 2004 | 05:39 PM
syrinx's Avatar
New User
Default Re: (RTW DC2)
I just replaced my plugs for the first time and I replaced them with Denso Platinums from Autozone. They were $5.99 each. part number PK20PR-L11.
The "stock" ones that I removed were the exact same plugs, same number and everything. So... stock can be had for much less than $15 each!
Old Apr 4, 2004 | 09:08 PM
110 South's Avatar
Default Re: (syrinx)
BKR7E
Old Apr 4, 2004 | 09:37 PM
baonest's Avatar
Default Re: (110 South)
the NGK-R's have a one year warantee, after couple months, get some residue from your exhaust, smear it on the tips of the plugs and tell them they are shot. and you get a free set. (well you first gotta pay for the new ones to come in, then you take your 4 plugs and receipt and they refund your money)
Old Apr 4, 2004 | 09:39 PM
uNF$@#!'s Avatar
Default Re: (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">the NGK-R's have a one year warantee, after couple months, get some residue from your exhaust, smear it on the tips of the plugs and tell them they are shot. and you get a free set. (well you first gotta pay for the new ones to come in, then you take your 4 plugs and receipt and they refund your money)</TD></TR></TABLE>
fraud. awesome baonest.
Old Apr 4, 2004 | 11:19 PM
gsr-2nr's Avatar
Default Re: (Soup ****)
denso iridium
Old Apr 5, 2004 | 06:58 AM
andrewasf77's Avatar
not to hijack the thread but what plugs do you guys recommend for 12.5 compression?
Old Apr 5, 2004 | 07:03 AM
Philly_NBP_R's Avatar
Default Re: OEM SPARK PLUGS OR NGK (andrewasf77)
Autozone has denso platinum replacement plugs for ~$7 each...
I swapped em at 60k miles and havn't had a problem since. They did seem to smooth the idle a bit.
Old Apr 5, 2004 | 08:53 AM
mistersparco's Avatar
washuuu
Default Re: OEM SPARK PLUGS OR NGK (Philly_NBP_R)
Stupid Question, but here goes.
For the 60k mark, what needs to be serviced?
TIA
Old Apr 5, 2004 | 09:33 AM
MugenH22AccordGirl's Avatar
I like NGK.
keybraker87
Dec 1, 2010 05:44 PM
fw190bvi
Dec 11, 2003 07:08 PM
SpyderZEX
Aug 28, 2003 04:58 AM
Knight2000
Oct 11, 2002 05:14 AM
MintyDip
Jul 1, 2002 12:42 PM
