those w/ neuspeed short shifter....need a little help
it comes w/ new bushings, but what i'm not sure is where the round bushing goes 'cause it definitely isnt going to stretch around the ball. i think i'm suppose to use the stock rubber seal and plastic friction thing that goes around the ball, but i dont want to leave anything out.
its the round yellow bushing next to the stock rubber seal...how does it hook up? tia
i believe the round yellow one goes at the bottom of the shifter connecting to the linkage. It should look like the stock one but different colors..
hey thanks for the reply but there is no stock counterpart for the round yellow bushing. i can always reassemble everything w/o the round yellow bushing but i figure neuspeed threw it in for a reason.
the yellow round one goes where the shifter linkage connects to the transmission....follow the linkage to the tranny and u will see a black rubber circle like that one. replace it with the yellow circle. It isnt hard to find, but getting the stock one off and the new one on takes a little time and skill.
what kit is that, cause i got a neuspeed shifter bushing set and the one that goes near the transmission, has a bigger hole and the spacer is too small to fit...
