first time pulling the head (b16a2), need some help...
Old Apr 1, 2004 | 11:49 AM
turbosi03's Avatar
Default first time pulling the head (b16a2), need some help...
hey guys, I'm at the point where I spent WAY too much money and it's time to do things myself... god damn boost spike got me which could have been prevented if my boost controller was connected, but thats another topic...
Update:
The head is now off... the gasket looks fine along with the deck and cylinder wall, but I'm not sure if I'm inspecting things right... would my next step be to take the piston out to inspect the rings?
my last compression numbers were: 175, 90, 180, 180
cyl #3 is the problem
here's the head surface, cylinder #3 is second one from right in this pic:
Please let me know what you think? I'll take any pics that will help, just let me know...
thanks for any input!
Modified by turbosi03 at 1:17 PM 4/3/2004
Modified by turbosi03 at 1:19 PM 4/3/2004
Modified by turbosi03 at 1:43 PM 4/3/2004
Old Apr 1, 2004 | 02:12 PM
GruvyTune's Avatar
New User
Default Re: first time pulling the head (b16a2), need some help... (turbosi03)
Dustin,
you are indeed brave but certainly following in the footsteps of many of us.
You are only looking to remove the head.
If you were smart (well you are but let me rephrase and say thinking ahead), you would have marked your timing belt and cam gears and crank position with a crayon or marker so that you may when you put things back together, just slip the belt back over the gears in its original position and be sure your timing wasn't affected. I doubt you thought to do that and its not an easy task anyway with the engine in place or at least be prepared to cut up your knuckles doing it.
In any case, you leave the cam gears on. There is no need to remove them.
you take off the cam holders and the camshaft with the gear lifts out. You dont touch the valve adjusters but when you are all done, I advise setting them anyway since its a 15min job to do.
Old Apr 1, 2004 | 03:12 PM
kreush33's Avatar
Default Re: first time pulling the head (GruvyTune)
you can also leave the intake manifold on and save yourself one more gasket to buy, i did this and it wasn't that hard at all to take the head off with the manifold still attached
Old Apr 1, 2004 | 04:24 PM
turbosi03's Avatar
Default Re: first time pulling the head (kreush33)
thanks Torin! I did not think of marking the timming belts with the gears. I thought the mark on the crank pulley along with the cam gear marks would alow me to line up everything in order to put the belt back on the way it was...??
is this not true? or are you just telling me it will be a pain in the ***?
Old Apr 1, 2004 | 05:58 PM
GruvyTune's Avatar
New User
Default Re: first time pulling the head (turbosi03)
no. you will have to reset your entire timing mechanism to be absolutely sure. ie set piston to TDC along with the cams at zero (TDC marks lined up) and crank pulley mark zero'd.
You'll be able to do this without loosening the timing belt adjuster if you take your time and carefully slip the timing belt back on the cam gears a little at a time but for the time it takes, i recommend just loosening the timing belt adjuster and doing it as it says in the helms. no different than if you were changing a timing belt.
Old Apr 1, 2004 | 06:40 PM
paybac4223's Avatar
or if he was really smart( i'll also say thinking ahead) he would have did a search and he would have found this thread....
https://honda-tech.com/zerothread?id=810161
Old Apr 1, 2004 | 08:53 PM
turbosi03's Avatar
Default Re: first time pulling the head (paybac4223)
nice link paybac4223, don't have to be the regular HT wise *** though... I always do searches before I post but a lot of times I get crap for results. a lot of the threads I find having simular questions to mine with replies such as "do a search"...
anyway, thanks for the replies... I now have the answers I was looking for. the head is ready to be removed with the exception of the intake bracket bolts I over looked. now I know to get the bolt from under the car thanks to paybac's searching skills
with any luck (which hasn't hit me yet) the only problem will be the head gasket. lets see what I find...
Old Apr 2, 2004 | 11:16 AM
paybac4223's Avatar
LOL....sorry bro i usually am not a wise azz.... i was just giving you a hard time in good nature hope the write up helps....
Old Apr 3, 2004 | 09:20 AM
turbosi03's Avatar
bump for help... updates at top...
Old Apr 3, 2004 | 11:44 AM
GruvyTune's Avatar
New User
its your ringlands
LuckyJDM
Sep 6, 2013 04:04 PM
Turbocivic94
Jun 19, 2009 10:28 AM
vi3t00si
Mar 27, 2006 06:30 PM
turbosi03
Apr 6, 2004 06:24 PM
