what rpm should i set the Vtec kick in point for a GSR engine....
i have a B18C in my hatch, and i just install a Apexi VAFC on it, and wonder what RPM you guys set it at, and as for the fuel adjustment, did you guys have any idea of how to set it up?
Thanks
Thanks
what cams are ya running it they're stock keep it at 4400. Tune with a dyno that has a wideband o2 sensor
[Modified by FAST94GSR, 9:01 PM 10/24/2001]
actually, i am using web cams with gear, port and polish head with bore out throttle bodies, i know i should get the car on the dyno, but i just don't get the time for it, anybody got a similar setup and with experience with the VAFC? maybe i can try their setup and see how it work, right now i just lead out -1% all the way through the powerband....i know this might not be right, but i am currently burning fuel, any help will be much appreicated
ha I tried web cams back in the day and they didn't gimme any more power than type r cams.
Anyway what is your fuel press set at? I'd up your vtec xover to 5000. You're gonna have to look at your plugs to see how you're running. Do you have air fuel meter, like a halmeter af30 or greddy. Don't trust that Autometer pos its very inaccurate.
2kdrift
Jun 6, 2016 03:45 PM
JG Luder
Sep 6, 2001 01:51 PM
