check engine light 2000 ls after oil/filter change
Old Mar 31, 2004 | 09:48 PM
azncollegeguy's Avatar
Default check engine light 2000 ls after oil/filter change
I just performed an oil and filter change on my Integ 2000 LS
regular oil filter and 4 bottles of the usual oil
The first day it was fine, the next day check engine light pops on ( not the maintenance required light ). I feel not enine problems?
Does anyone know what is wrong??
Can a loose oil filter cause that? I see not leeks, but have not check under the car to see if the filter is loose.
ACG
Old Mar 31, 2004 | 10:46 PM
blueeg's Avatar
Default Re: check engine light 2000 ls after oil/filter change (azn_college_guy)
nope a loose oil fitler will not make the check engine light come on. u must have knocked loose a vacuum hose or something. check your hoses and wires. if they look ok find out what the code is for then check again.
Old Mar 31, 2004 | 11:24 PM
iwannaboostmyteg's Avatar
Just press the reset button under the dash by the steering wheel and if the light comes on again then check everything else. Reseting it once wont kill anything or hurt anything.
Old Mar 31, 2004 | 11:25 PM
B2FiNiTY's Avatar
Check your gas cap.
Check your oil level.
Old Mar 31, 2004 | 11:26 PM
B2FiNiTY's Avatar
Default Re: check engine light 2000 ls after oil/filter change (iwannaboostmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwannaboostmyteg &raquo;</TD></TR><TR><TD CLASS="quote">Just press the reset button under the dash by the steering wheel and if the light comes on again then check everything else. Reseting it once wont kill anything or hurt anything.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_college_guy &raquo;</TD></TR><TR><TD CLASS="quote">
ACG</TD></TR></TABLE>
Please read.
Old Mar 31, 2004 | 11:28 PM
GSRrR's Avatar
that resets the maintanence required light, not the check engine light.
to find out what is wrong, jump the cable under the dash on the passenger side and read the code. light will blink, long=10 short =1
http://www.londonautoclub.org/...s.htm
Old Apr 1, 2004 | 01:38 AM
lol I wasn't reading that well I guess oh well.... hahaha thanks for correcting me on that guys... DON'T pay any attention to me on this one.....
Old Apr 1, 2004 | 07:02 AM
Default Re: check engine light 2000 ls after oil/filter change (GSRrR)
Wow thanks,
Jump the cable? Do you mean take take it to the shop? Or is this something simple i can do? If so please let me know.
Thanks alot,
acg
Old Apr 1, 2004 | 07:07 AM
You're right, this morning i went under the car to check everything out... The oil filter is good and tight the oil nut is tight too.
Yes this is a strange problem. I've done oil changes many times, but this time check engine light pops up. I did notice that the auto trans fluid was kissing the low level i toped it off but still light didn't turn off. I wonder if i drove it around for a bit it would fix the problem.
i will continue to search if i find out i'll let you guys know....
if anyone know please let me know....
it is an integra ls 2000 automatic
thanks guy,
acg
Old Apr 1, 2004 | 07:10 AM
95LSB18's Avatar
Check and see what codes ur ecu is throwing
IT easy click on the link it will show u how to do it
http://www.team-integra.net/se...ID=34
Old Apr 1, 2004 | 12:52 PM
GSRrR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_college_guy &raquo;</TD></TR><TR><TD CLASS="quote">Wow thanks,
Thanks alot,
acg</TD></TR></TABLE>
edit try again
Modified by GSRrR at 2:50 PM 4/1/2004
Old Apr 1, 2004 | 01:04 PM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_college_guy &raquo;</TD></TR><TR><TD CLASS="quote"> I wonder if i drove it around for a bit it would fix the problem.
Thats definitly not going to fix the problem, b/c if it did everyone would be doing it. Just jump the freaking ecu and get the code thats causing the CEL (check engine light). You will then know right away, without guessing, what the problem is. Plain and simple.
Old Apr 1, 2004 | 01:40 PM
Default Re: check engine light 2000 ls after oil/filter change (95LSB18)
sorry that link does not work, can you resend the link again?
acg
Old Apr 1, 2004 | 01:49 PM
Ok, temp fix....
This might be the problem...
Low in auto trans mission fluid...
It was kissing the low level this morning, i filled it up to the high level with dextron 3, the problem did NOT GO AWAY, even after driving about 30 mins.
I did some other stuff. Did more research but didn't touch the engine....
finally had to drive the car around this afternoon, for about 2 hr, running usual errands, strangly the light has gone away.....
weird huh? Could it be the auto trans fluid? Could it be something else reoccuring? I dont know, but that temp fix fixed the problem
i'll let you guys know if it comes back...hopefully not makes me nervou
Thanks alot guys...
spiderman_rej
Mar 21, 2008 08:46 PM
SIvic2000
14
Feb 19, 2007 07:22 PM
legends
Jun 8, 2006 08:36 PM
shraz
13
Jun 8, 2006 08:11 PM
blk97lude
May 5, 2003 10:53 PM
