helicoil install....can u stack the inserts?
Old Mar 31, 2004 | 09:07 PM
s73's Avatar
s73
New User
Default helicoil install....can u stack the inserts?
got a d16 tranny....the 3 mount bolt holes (u know 2 studs and one bolt) are stripped to hell, and i got a helicoil kit....and it seems like the inserts seems to be a bit shorter then the org. bolt holes
so i am wondering, can u "stack" the thread inserts.....if so....how do u do it? has any one done this before? Please let me know
thanks
Old Mar 31, 2004 | 09:29 PM
Sed8ed's Avatar
Default Re: helicoil install....can u stack the inserts? (s73)
Yes, you can stack the coils... I helicoiled my block (all head studs) and I had to stack 2 coils per hole... Tap the holes to the bottom depth of the original thread (if you don't have much experience tapping holes in aluminum post and i'll walk you through it) and first thread one coil into the hole to the bottom and break the tien off... use a small flat head screwdriver with some grease on the tip to pull the tien out of the hole then thread the second coil ontop of it, use the same method to get the tien out of the hole
Voila, one rethreaded hole
If you arn't comfortable doing this, it shouldn't cost more than $60 to get a machine shop to do it. ($10 per coil, installed, 2 coils per hole)
good luck
Old Mar 31, 2004 | 09:52 PM
s73's Avatar
s73
New User
Default Re: helicoil install....can u stack the inserts? (Sed8ed)
thanks for replying to my thread.......i never had experience in taping holes in aluminum......is there something i should look out for? (this is the first time i am using the helicoil kit......
i would love to have any info on this topic!
thanks a lot
Old Apr 1, 2004 | 10:05 AM
s73's Avatar
s73
New User
bump
DeeEx Rex
10
Jul 29, 2010 11:02 AM
allmotorb18c14door
Welding / Fabrication
Mar 2, 2007 12:04 PM
a1320addict
Aug 26, 2006 05:19 PM
gsrmike
Apr 11, 2004 12:06 PM
lsvtecracer
Nov 5, 2003 10:51 AM
