GSR swaps with OBD1 conversion...exhaust cam solenoid...
Old Mar 31, 2004 | 07:28 PM
*Boostwerks*'s Avatar
Default GSR swaps with OBD1 conversion...exhaust cam solenoid...
There is a 1 wire (what appears to be a solenoid) on the exhaust cam. What do I need to wire this up too?
Thanks for any info!
Bryson
Old Apr 1, 2004 | 02:07 AM
Fobtions's Avatar
Default Re: GSR swaps with OBD1 conversion...exhaust cam solenoid... (Bryson)
vtec solenoid
Old Apr 1, 2004 | 11:55 AM
Ok damn I'm a moron. I was thinking that was the 2 wire plug on the side of the head...wow.
Old Apr 1, 2004 | 07:55 PM
Fobtions's Avatar
Default Re: (Bryson)
the 2 wire one is the vtec pressure switch
Old Apr 2, 2004 | 10:13 AM
Ok. So then I'm assuming the 1 wire sender right next to that is the coolant temp?
Old Apr 2, 2004 | 10:21 AM
YumVTEC's Avatar
no, the two wire is vtec oil pressure, the one wire is the vtec solenoid.
Old Apr 2, 2004 | 10:28 AM
Ugh.
Now your telling me something different. as I understand it, the solenoid on the Exhaust cam is the VTEC solenoid. The 2 wire is the oil pressure switch. now I'm talking about the 1 wire sender right next to the 2 wire oil pressure switch on the side of the head (close to the gasket).
Needless to say, I can't wait until my Helms arrives... : /
Old Apr 2, 2004 | 10:36 AM
rsbad454's Avatar
3K posts....and you dont know where the wires go by now.............
Old Apr 2, 2004 | 10:48 AM
Default Re: (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">3K posts....and you dont know where the wires go by now............. </TD></TR></TABLE>
Haha...*******. For about 2980 of those posts, I've been a hardcore ZC'er. so STFU.
This is my first B series swap, and Helms is taking forever.
Old Apr 2, 2004 | 10:52 AM
fourthgenhatchB17's Avatar
That small one wire that's CLOSEST TO THE HEAD GASKET is the coolant temp gauge sender. Unplug it and see if your temp gauge still registers. Your ZC should of had this same exact sensor in the same spot....
Old Apr 2, 2004 | 10:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">That small one wire that's CLOSEST TO THE HEAD GASKET is the coolant temp gauge sender. Unplug it and see if your temp gauge still registers. Your ZC should of had this same exact sensor in the same spot....
Yeah, thats the one that I was talking about...thanks!
I'm not having any problems yet. Just getting the wiring setup on my harness.
Old Apr 2, 2004 | 04:30 PM
Wes V's Avatar
Bryson;
I'm currently wiring up (OBD1) the 95 B18C that I've put in my 89 SI. Here are the answers (as I understand it)
On the side of the head (at the end of the exhaust cam) there is a "module" (aluminum piece) that is for the VTEC. On it there is a one wire connection and that is the VTEC solenoid (activates the VTEC by allowing oil pressure to pass). Also on that module is a sensor that is hooked up the ECU telling it the oil pressure (the ECU will not engauge the VTEC if the oil pressure isn't high enough).
This oil pressure sensor is different than the "one wire" one that is mounted on the back of the block (and also goes to the ECU)
On the head, near the "module" are two sensors and they are both for water temperature. The one wire one goes to the gauge on the dash. The other goes to the ECU.
There is a third water sensor that is mounted on the thermostat housing. That one works (in parallel with the ECU) to turn on the radiator fan.
It all seems pretty crazy (three sensors for water temperature?!?!?!), but that's what it seems to be.
Wes Vann
Old Apr 3, 2004 | 11:24 AM
hehe...Thanks a lot man!
yeah I was kinda wondering which one of those water temps sensors, was the fan switch. The one on the ZC is on the back of the block.
LUiS010606
May 7, 2009 12:05 PM
jdmbreed
Sep 26, 2005 07:56 AM
Bimmerman
Jun 15, 2005 05:23 PM
mr. carpenter
May 5, 2004 09:47 PM
InfamousRS
May 19, 2002 10:56 AM
