Are the axles bad
Old Mar 31, 2004 | 08:49 AM
I20I3's Avatar
Default Are the axles bad
All of a sudden today I am hearing a squeaking coming from the passenger side in the front. It's constant and not a clicking... almost sounds like something rubbing... Is this a sign of an axle that needs to be replaced?
Old Mar 31, 2004 | 09:06 AM
SlowAssAccord's Avatar
Default Re: Are the axles bad (I20I3)
if its a constant high pitch squeak could be your break pads. some pads have like a safety wear feature, when the pads get low a wire in the pad pops out and touches the rotor.
Old Apr 1, 2004 | 09:34 AM
Bushwhacker's Avatar
We've had this type of squeel a few times on our '92 Accord LX - came up suddenly and loud. It was caused by a stone that gets lodged somewhere between the brake caliper and disc. Always been able to dislodge it by turning the wheel back & forth and applying brakes. Scary as hell the first time .... now we know this will happen occasionaly with no problem dislodging it.
HTH
Old Apr 1, 2004 | 04:08 PM
tommymoose's Avatar
Default Re: Are the axles bad (Bushwhacker)
I have a 96 LX and alot of the time when its humid out (after or during rain) the front passenger side makes a sqealing noise and it keeps making it for a couple miles then it will stop and make the noise again about 20 miles later. I've had the pads replaced and the rotors checked and they dont know what the problem is. Anybody have any ideas? Basically the same story as his ^ but mine only happens when its damp out if that may provide some more clues.
Chubz
19
Jun 16, 2008 10:02 PM
THALADOR
Nov 6, 2004 08:31 PM
sl0wED
May 15, 2004 08:42 PM
silvercivicgrl
13
Aug 12, 2003 08:17 AM
Charlie Moua
Jun 30, 2003 02:44 PM
