Screeching noise from front right wheel well
Old 08-11-2003, 02:43 PM
silvercivicgrl's Avatar
Default Screeching noise from front right wheel well
I think its my brake pads but tell me if I'm wrong. Its coming from my pass front right wheel well and it only makes noise when I'm acclerating (not when I'm braking) And its a high pitched screeching/squealing noise. It usually happens for a few seconds, goes away for a little bit, then starts up again. I did a search and I think its my brake pads (since it is about time to change those). Any ideas?
Old 08-11-2003, 03:04 PM
97civicdx's Avatar
Default Re: Screeching noise from front right wheel well (silvercivicgrl)
If it was the brake pads, it would screech when u apply the brakes.
Did you take a look at your axles, CV boot ripped?
Old 08-11-2003, 03:09 PM
Default Re: Screeching noise from front right wheel well (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">If it was the brake pads, it would screech when u apply the brakes.
Did you take a look at your axles, CV boot ripped?</TD></TR></TABLE>
Nah I was hoping it wasnt that I'm having one of my friends come over right now to take a look at it with me. Man why does crap like this always come at a bad time?
Old 08-11-2003, 03:31 PM
hrdkorlude's Avatar
sounds like the brake pads, it's like a warning to change them asap, before you tear up your rotors.tell us what happened.
Old 08-11-2003, 03:52 PM
97civicdx's Avatar
She said it only happens during acceleration....
Old 08-11-2003, 04:05 PM
mMmdoOonut's Avatar
if they are your original pads on that 99ex, they have a squeel to remind you to change them... most likely what that is...
Old 08-11-2003, 04:07 PM
EG2 SiR's Avatar
Default Re: Screeching noise from front right wheel well (mMmdoOonut)
if someone happened to bend the dust shield, it may be contacting the rotor... That happened to me once...
Old 08-11-2003, 04:14 PM
lsvinny's Avatar
Default Re: Screeching noise from front right wheel well (EG2 SiR)
how many miles since you last changed your pads. If its the pads it will go away when you hit your brakes.
Old 08-11-2003, 07:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">if someone happened to bend the dust shield, it may be contacting the rotor... That happened to me once...</TD></TR></TABLE>
my bf said it might be the rotor shield. I think it maybe that since it started all of a sudden and I remembered I just got my brake pads replaced last summer. Also my friend checked those out and said they were not worn down either. So hopefully its just that shield and it wont cost me an arm and a leg to fix. I'm going to get it checked out tomorrow morning after my class though
Old 08-11-2003, 07:04 PM
-Gambit-'s Avatar
it might be a wheel bearing going out.
Old 08-12-2003, 12:45 AM
94LsEgHatch's Avatar
its your brakes warning you to change them. thats how brakes are made, when they are going out the squeek and when you step on the brake they wont make any noise. i know a lot of people are going to say im wrong, but change your brakes and your problem will be solved. good luck!
Old 08-12-2003, 07:21 AM
civickidd99's Avatar
Default Re: Screeching noise from front right wheel well (94LsEgHatch)
this may sound stupid, but a while back on my car mine started making this horrible screeching sound and when I looked at the dust shield on the back of the rotor there was this LITTLE pebble stuck between the shield and the rotor. Once I took it out the noise was gone. Hope this helped!
Old 08-12-2003, 07:38 AM
FifthGearOnline's Avatar
you will no that its the dust shield if it sounds like a metal shovel rubbing on concrete.
Old 08-12-2003, 08:17 AM
Default Re: (FifthGearOnline)
it was my inner brake pads. thanks guys
91CVCHATCH
08-23-2007 01:01 PM
pcguy760
04-08-2007 03:52 PM
1998_4dr_gsr
06-14-2004 09:20 AM
CerealKiller1117
09-18-2003 10:05 PM
RolioPolio
06-29-2002 01:38 AM
Quick Reply: Screeching noise from front right wheel well
