eratic idle
It's probably your FITV (fast idle thermo valve)located under the TB...take off the 3 10mm bolts, then the 2 8mm bolts that holds the plate on, then screw in the odd-looking white thing...take 2 flathead screwdrivers to do this...that acts as a vacuum leak, and probably your problem.
