code 54, obd1 engine obd2 ecu
Old Mar 31, 2004 | 07:10 AM
Javier23's Avatar
Default code 54, obd1 engine obd2 ecu
99 civic cx, 95 jdm b16, obd2 p72
Will a jdm obd 2 ecu ignore the ckf being non existent?
Anyone know how to get rid of the code 54? I am out of ideas. Any tricks as far as wiring the ckf plug into the distributor to trick the ecu?
It runs fine on the obd 1 ecu but I have to run the obd 2 to pass emissions.
Old Mar 31, 2004 | 02:25 PM
kreush33's Avatar
Default Re: code 54, obd1 engine obd2 ecu (exsleeper)
search i read the answer to your problem somewhere
oops sorry it was code 91, heres the thread anyway though
https://honda-tech.com/zerothread?id=767817
Old Apr 1, 2004 | 04:59 AM
EE_Chris's Avatar
CKF sensor has nothing to do with the distributor, its mounted on the oil pump. There is no way to fool the ECU to get rid of this code....you need a different ECU.
Old Apr 1, 2004 | 06:00 AM
Javier23's Avatar
Default Re: code 54, obd1 engine obd2 ecu (EE_Chris)
sorry if this sounds dumb, but will a newer usdm oil pump fit in this older jdm motor?
Old Dec 6, 2011 | 07:42 AM
thericepatch's Avatar
Motor specifics would be good, but in general, yes the obd2 oil pump will fit on the same series obd1 and jdm motors
Old Dec 6, 2011 | 07:48 AM
kyden's Avatar
look up ckf bypass.
Old Dec 6, 2011 | 08:38 AM
HondaPartsHero's Avatar
Technical Hero
This thread was from 2004
Old Dec 6, 2011 | 05:32 PM
hybridmiklo's Avatar
there is a way to bypass it. Check out the hybrid section. I found it there
lakerschamp2000
Jan 15, 2006 09:51 PM
Javier23
Mar 31, 2004 01:23 PM
