SOHC DSM T25 qustions (searched)
Old Mar 31, 2004 | 02:03 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default SOHC DSM T25 qustions (searched)
Hello all..
i have a few questions that are still un answered.
This is my setup.. stock high milage D15 OBD1 Hatch. Trying to put in a T25 custom piping to retain AC. (custom manifold, IC and charge pipes)
The DSM 2nd Gen T25 is 8 PSI actuated ( best of my knowlage ).. what are my optoins to keep the cost down?
if i only plan on puttin around town, NEVER red linning, or abusing my little G ride.. can i get away with stand alone engine management? and a few check valves for the MAP?
FUEL? FMU? nessisary? 5PSI? upgrade pump or can i get by?
MAP? Missing link or check valves?
and hack? no hack needed if i FMU?
like i said.. strickly around town.. nothign fancy.. i really could careless if the turbo made substancial power.. just wanted the sound.. but the more and more i look at it.. its costing me. lol
Old Mar 31, 2004 | 04:29 AM
Finest's Avatar
Default Re: SOHC DSM T25 qustions (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">.. i really could careless if the turbo made substancial power.. just wanted the sound.. but the more and more i look at it.. its costing me.</TD></TR></TABLE>
You should look into the fake FMIC and fake BOV sound if you want to keep the costs down.
Otherwise, you can use either the FMU+check valve setup. Or the AFC hack (which I would recommend for low boost setups).
And about never redlining the car....yea right. After you experience boost, you'll want more and more, watch!
Old Mar 31, 2004 | 04:54 AM
SOHC_MShue's Avatar
just want it for the sound? Buy one of those fake bov sound boxes.
Old Mar 31, 2004 | 06:34 AM
1point5CRX's Avatar
Default Re: SOHC DSM T25 qustions (SOHC_MShue)
check d-series.org and go to the forced induction page, many using HF manifold with adaptor plate on a 14b or t2 slow, various fmic, homemade piping, afc hack etc.. theyll show ya how to keep it cheap and somewhat reliable
Old Mar 31, 2004 | 06:49 AM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">if i only plan on puttin around town, NEVER red linning, or abusing my little G ride.. can i get away with stand alone engine management? and a few check valves for the MAP?</TD></TR></TABLE>
no you cant get away with stand alone it will cost more than youre whole turbo setup. plus with a standalone you dont need check valves.
Landon
Old Mar 31, 2004 | 07:39 AM
specv5150's Avatar
what i your budget....
Mine is somehwere around 1750 and this is what I will be getting
Vtec92civic manifold and IC piping 550
some small turbo no more than 150
FMIC no more than 250
SAFC no more than 275
450 DSM/resistor box-80
oil like it from stealthmode at HMT -90
BOV no more than 150
Fluids/filter-50 (change oil and prolly do a coolant flush too)
K&N air filter-no more than 50
autometer boost gauge brand new was 30
autometer water temp-was 30
6 gauge pod holder-50
It can be done for ALOT less than that but I chose to get most the stuff brand new vs shopping around. The only thing that will be used is the turbo and DSM until I can afford a new turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">Hello all..
like i said.. strickly around town.. nothign fancy.. i really could careless if the turbo made substancial power.. just wanted the sound.. but the more and more i look at it.. its costing me. lol </TD></TR></TABLE>
Old Mar 31, 2004 | 11:24 AM
Built B16A's Avatar
Default Re: SOHC DSM T25 qustions (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">what i your budget....</TD></TR></TABLE>
well.. my budget is low.. not cuz im broke.. cuz i dont' really wanna spend money on something i know will never make serious power.. i already have a 12 second car in the garage (hence my fully built B16). so far im in this turbo kit im peicing together about 500 bucks. and its AC compatable. but im almost ready to hit the streets.. i just need to learn about my fuel now, and whats good enough for low PSI..
im thinkinging missing link, and FMU 8:1 and no inline pump.
Old Mar 31, 2004 | 11:30 AM
kpt4321's Avatar
Old Mar 31, 2004 | 12:41 PM
Built B16A's Avatar
Default Re: SOHC DSM T25 qustions (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
... </TD></TR></TABLE>
the engine has 233 THOUSAND MILES!
Old Mar 31, 2004 | 01:52 PM
specv5150's Avatar
dont listen to him.....as long as you know you arent a ricer...who gives a **** what some guy on teh internet thinks. I will atest that noithing sounds better than a turbo spooling then shifting gears and hearing the BOV...Nice ****. Still alot of money to spend just for the sound though...especially when you can get those imitation BOV sounds for your exhuast for 30 bucks
Old Mar 31, 2004 | 06:25 PM
Built B16A's Avatar
well.. ive been talking to alot of poeple..
cheap exh. blow off valve imatators suck.
i belive this is my solution...
stock D15 in a EG hatch.
custom manifold and piping, tyrus 6" IC, and as far as management, we're going to run stock fuel supply, all with the exeption of running a B&M FPR set at 50SPI.. with a manual boost controler on teh T25 we're going to bring 5 PSI to the TB.. and keep an eye on the air/fuel, and boost.
for now, it should be ok. might run alittle rich at idle.. but running, should even out. im thinking of getting a EGT also..
Old Mar 31, 2004 | 08:57 PM
good luck
Landon
Old Mar 31, 2004 | 10:23 PM
FourG63 97GST's Avatar
Anyone here running a DSM T25?
because I remember the lowest boost I could get was like 11psi
Old Mar 31, 2004 | 10:32 PM
tilt's Avatar
Default Re: (FourG63 97GST)
i have a t25 on my d15. it spikes to 9psi, levels off around 7-8.
bare minimum youd prob want to do is fmu and check valves. I'd recommend 450cc injectors and a afc though... you can get them used for prob 50 and 200$
Old Mar 31, 2004 | 11:30 PM
egturbo's Avatar
"ONCE U GO BOOST U WON'T GO BACK!!"
Old Mar 31, 2004 | 11:31 PM
sporkcrx's Avatar
Default Re: SOHC DSM T25 qustions (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">"ONCE U GO BOOST U WON'T GO BACK!!"</TD></TR></TABLE>
that's right baby!
Old Apr 1, 2004 | 08:05 AM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to him.....as long as you know you arent a ricer...</TD></TR></TABLE>
He's buying a whole turbo kit for the sound. End of story.
Old Apr 1, 2004 | 09:25 AM
Built B16A's Avatar
He's buying a whole turbo kit for the sound. End of story.</TD></TR></TABLE>
atleast it is a whole complete kit, instead of some gay box you put in your 5" exhaust tip.. hahah
Old Apr 1, 2004 | 04:35 PM
hotintegranights's Avatar
boost sounds good but i think 99.9% of the peeps that boost is cause they want more power not more sound, for info on this go to homemadeturbo.com and the 50psi fuel reg is not gonna work, go with afc hack (apexi afc and dsm 450 6-16 psi or fmu (fmu and walbro fuel pump)4-8 psi
egturbo
Oct 6, 2004 02:01 PM
xXx Justin xXx
Dec 14, 2003 08:18 AM
spike
Sep 18, 2003 01:59 PM
greekspeed
Aug 18, 2003 09:53 AM
SimonsTeg
Jan 21, 2003 06:23 PM
