fuel gauge wont work
Old Mar 30, 2004 | 05:45 PM
spoon063's Avatar
Default fuel gauge wont work
i have a 99 cluster in a 94 teg and the gas gauge is the only thing that doesnt work, w/o putting the stock cluster back in, anyone know the wires to jump it or someway to make it work ? i'm driving it across country in a couple days.... any help would be appreciated... thanks
Old Mar 30, 2004 | 05:52 PM
its WANG yoO's Avatar
Default Re: fuel gauge wont work (spoon063)
someone help this foo!
Old Mar 30, 2004 | 06:14 PM
Kataku2K3's Avatar
Default Re: fuel gauge wont work (inJDMtegra)
The clusters should be the same but if possible and you have another Teg cluster I would test it first. If it does the same then it's probably safe to say that the problem lies in the wiring (sender to cluster) or the sender itself is bad. If you don't have another cluster to test with first I would go straight to the wiring/sender (with a DMM check for continuity from the sender wire at the gas tank to the cluster pinout for your fuel gauge reference) Good Luck
Old Mar 30, 2004 | 10:27 PM
spoon063's Avatar
Default Re: fuel gauge wont work (Kataku2K3)
I changed the green backing from my stock obd1 cluster onto my obd2 cluster.... so far only the open door light came on....
MTarry
11
Jan 15, 2013 06:46 PM
JDM_WHR
10
Jun 7, 2010 08:50 AM
blasterman87
Feb 28, 2010 08:37 AM
roger93si
Feb 12, 2007 01:31 AM
