What did you guys use to put on aftermarket lip?
Old Mar 30, 2004 | 01:32 PM
92BlackSi's Avatar
Default What did you guys use to put on aftermarket lip?
I am putting the TypeR front and rear lip on my car now. Should I use screws/bolts/3m tape etc??? What would you all suggest?
Old Mar 30, 2004 | 02:24 PM
4G63's Avatar
Default Re: What did you guys use to put on aftermarket lip? (92BlackSi)
3m emblem tape
and those bolts that dont have a top, i think they are called carriage bolts. The ones that have a flush head
Old Mar 30, 2004 | 02:26 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: What did you guys use to put on aftermarket lip? (4G63)
i use bolts and washers. what i do is drill a hole thru the lip and the bumper. i slip the bolt thru with a washer and tighten it down with a nut on the other side.
Old Mar 30, 2004 | 06:49 PM
Mugen Hamster's Avatar
Default Re: What did you guys use to put on aftermarket lip? (AzntaggeR)
A few self-tapping screws worked for me. No tape needed. I tested it by liffting up the bumper while holding the lip, and i shook it rather violently for a good amount of time. No lip mounting failure was recorded.
Old Mar 30, 2004 | 07:12 PM
Shaun's Avatar
yeah, self-tapping screws is what i used for my mugen and si lip
Old Mar 30, 2004 | 08:00 PM
XxSOHCDriVerxX's Avatar
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">yeah, self-tapping screws is what i used for my mugen and si lip </TD></TR></TABLE>
me too
Old Mar 31, 2004 | 05:44 AM
92BlackSi's Avatar
Did you guys use the bolts/self tapping screws on the sides by the fender and underneath the lip in the middle?
Old Mar 31, 2004 | 06:57 AM
ebelp's Avatar
Default Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">Did you guys use the bolts/self tapping screws on the sides by the fender and underneath the lip in the middle?</TD></TR></TABLE>
Yes.
Old Mar 31, 2004 | 07:18 AM
Grimm's Avatar
Default Re: (ebelp)
i just used two screws on the ends... it kinda hangs over the stock lip
Old Mar 31, 2004 | 07:23 AM
b20turbojason's Avatar
Default Re: (Grimm)
rivets is what i used
Mark D. Surface
May 24, 2007 02:23 PM
hcivic99
Jun 2, 2005 12:16 PM
jeremy.
31
Apr 24, 2004 09:40 PM
pphan3
Feb 17, 2004 10:47 AM
inty2511
Apr 11, 2003 05:39 AM
