Turn Signal socket ripped out
Old Mar 30, 2004 | 12:48 PM
Type Wah's Avatar
Default Turn Signal socket ripped out
My passenger side turn signal socket on my 95 integra was ripped out and now my turn signal/hazards do not work. I ordered the sockets from acuraautomotivepart.org and I'm waiting for them to come in. My question is if I connect the socket to my turn signal harness, would everything work? since it was ripped out, should I just tape the wire to the sockets?
BTW this is for my passenger side. My driver side turn signal turns on but the signals don't work because I'm missing the passenger driver side.
TIA for any help
Old Mar 30, 2004 | 01:00 PM
Type Wah's Avatar
Default Re: Turn Signal socket ripped out (Type Wah)
Has anyone had to replace a turn signal socket (socket that holds the bulbs) or whole turn signal harness? If so, please help me on fixing mine.
Old Mar 30, 2004 | 01:03 PM
ONEhb2NR's Avatar
Same thing happend to my EG hatch it's never been the same . I would also like to know what needs to be done to fix it.
Old Mar 30, 2004 | 07:59 PM
Type Wah's Avatar
Up
Old Mar 30, 2004 | 10:00 PM
Deluzional's Avatar
Default Re: (Type Wah)
Well if the wires are still intact, then you dont have much to worry about. As long as your re-wire it, everything should be good as new
Old Mar 30, 2004 | 11:24 PM
Type Wah's Avatar
Default Re: (Deluzional)
The sockets were ripped from the wire harness. So if I wire it to the new socket, everything should work fine right?
Old Mar 31, 2004 | 08:04 PM
Type Wah's Avatar
I went to a local shop & they wanted $160 to get it fixed with brand new harness from Acura... Hahaha, i left...
Old Apr 3, 2004 | 10:26 AM
Type Wah's Avatar
Anyone had this experience?
Old Apr 3, 2004 | 12:59 PM
Deluzional's Avatar
Yea this happened to me too, but all i did was re-wire it and it worked again. Check it out first and try to see what happens when you re-wire it. Its easy, unless your wires are not visible, you are going to have to locate its origin through the loom and wire that up
blockablocka
Honda Civic (2001 - 2005)
Mar 26, 2015 02:43 PM
champ421
Lighting
Jan 6, 2015 08:43 PM
OUT OF ORDER ROB
Feb 15, 2014 07:44 AM
Electrodynamic
Mar 1, 2005 04:24 PM
