High Idle!!!! How to get rid of it????
Old Mar 30, 2004 | 09:45 AM
streetlvlhatch's Avatar
Default High Idle!!!! How to get rid of it????
OK..... I have ls/vtec motor swapped into my 96 civic hatchback. I am running an obd1 p72 ecu. When i start the car cold, the idle is extremely high. It is like 2500-3000. When i first swapped the motors, i had a cel for tps. I adjust it to like 4.85 volts (or .485). The range it can have is like 4.8-5 volts. Will that little voltage lower it? As the car warms, the idle comes down. In closed loop it runs fine no problems. It is just when im in open loop that the idle is high. It is like 750 in closed too.
Old Mar 30, 2004 | 03:39 PM
Default Re: High Idle!!!! How to get rid of it???? (streetlvlhatch)
ttt
Old Mar 30, 2004 | 04:12 PM
SleepyHF's Avatar
adjust the throttle cable screws...
Old Mar 30, 2004 | 04:13 PM
SleepyHF's Avatar
could be MAP too...if voltage is low it wont throw a CEL
Old Mar 30, 2004 | 05:01 PM
Default Re: High Idle!!!! How to get rid of it???? (ConfusedHF)
The cable is all the way down... why would map do it?
Old Mar 30, 2004 | 05:05 PM
SleepyHF's Avatar
well the map senor on my friends 92 civic hatch went bad and his idle skyrocketed...check it
Old Mar 30, 2004 | 05:08 PM
engineboy's Avatar
the other dude is right about the map. My map just went bad yesterday, it fuked everything over, the idle can be anything from 1200-3000, it fluctatues everytime I stop. Then my gas is going like crazy, 80km=half tank gone. Check the map
twocross
29
May 3, 2011 01:03 PM
1nsoman1ac
Jul 29, 2009 05:48 PM
97ekb18b
Feb 29, 2008 09:30 PM
asianspeed
Feb 25, 2003 07:19 PM
civicracer1993
Feb 24, 2003 07:25 PM
