Need Help BOOSTING R!
Hello, I was wondering if anyone can give me some good advice on boosting my R.
I have a 92 civic CX with a JDM B18C R. I was thinking about boosting. How much boost can i run SAFELY on a stock block? Im planning to build the block, but not just yet. Let me know please! and what turbo kit works fine with this engine.
THANKS ALOT!
THANKS ALOT!
I would def reccomend lowering the compression with a thicker head gasket such as acometic or inline pro. I would def reccomend standalone such as hondata or aem ems. Its all about tuning. I plan on running 12 pounds on a stock block with just a thicker head gasket with a conservative tune. if you wanna be extra safe i would say to run 8-10pds. As for the turbo kit i would reccomend the rev hard stage 2 but you are better off parting togther a kit that would make more power and be the same price. You should def check out importparts.com where you can build your own kit yourself . Mine should be here any day. This is what my turbo setup consists of: good luck
inline pro log mani
sc34 precision turbo .63ar/69 trim
inline pro 2.5 in dp
drag intercooler piping
tial 38mm wastegate
hks ssq bov
drag intercooler rated to 400hp
rc 650cc sat inj w obd2 clips
walboro 255lph in tank fuel pump
cometic headgasket
hondata s200b p28 ecu
cm stage 4
inline pro log mani
tial 38mm wastegate
hks ssq bov
cometic headgasket
cm stage 4
