No Flexpipe or Spring nuts.
Old Mar 29, 2004 | 09:38 PM
B00ST2nR's Avatar
Default No Flexpipe or Spring nuts.
https://honda-tech.com/zerothread?id=815742
This should have been asked here in the TECH Forum.
Is it ok to run an exhaust setup without spring nuts and flexpipe?
Old Mar 29, 2004 | 10:11 PM
IrishDX's Avatar
Default Re: No Flexpipe or Spring nuts. (Skunk2nR)
No. Everytime you accelerate hard, your engine will torque. This will put stress on the exhaust joints. Something WILL break. The best route, adter reading the linked post, is the flex pipe. Before or after the cat. If at all possible, before, in the firewall area. Another option is to have new flanges welded on that can accomodate the spring bolts with a donut type gasket. Either way, the cost will be well worth it.
Old Mar 29, 2004 | 10:36 PM
EdBoon's Avatar
I've been running mine for 2 years with no flexpipe/spring nuts. No problems.
Old Mar 30, 2004 | 08:15 AM
Propulsion's Avatar
Default Re: No Flexpipe or Spring nuts. (EdBoon)
The owner of a exhaust shop freaked out when he saw that i had no spring bolts between the cat and header. He insisted that something will break and eventually just installed a set of spring bolts for free.
Just because it hasn't broken yet, doesn't mean it won't. do it right the first time.
Old Mar 30, 2004 | 11:00 AM
dfoxengr's Avatar
Default Re: No Flexpipe or Spring nuts. (SilverCIVIC96)
if the spring bolts break i always replace them with regular bolt/nuts, and havent had any problems yet
Old Mar 30, 2004 | 12:12 PM
d15nonvtec's Avatar
Default Re: No Flexpipe or Spring nuts. (hybridvteceg)
i had the spring bolts out on mine for the longest time then one day, my header cracked at the flange on the bottom, so i welded it and put a flexpipe in, all good since then
Old Mar 30, 2004 | 02:22 PM
B00ST2nR's Avatar
Default Re: No Flexpipe or Spring nuts. (d15nonvtec)
Ok... I can't afford anything to crack or break, so Flexpipe it is.
jdmark1
May 7, 2017 02:53 PM
NegativeXero
Nov 23, 2006 04:51 PM
Floored
Jul 17, 2006 07:37 AM
egzo04
Sep 30, 2005 06:44 PM
TAG
19
Jul 6, 2003 08:19 PM
