n2o or not!?
Old Oct 24, 2001 | 01:30 AM
mr2's Avatar
mr2
Default n2o or not!?
im trying to get a eg6 into the 13's.. without a turbo, what are my options or is n2o the way to go without a turbo or a supercharge.. list my options.. like port heads.. higher compression cams... anything?
Old Oct 24, 2001 | 04:43 AM
DragII's Avatar
25 Year Member
Default Re: n2o or not!? (white eg)
nitrous is safe, only when used properly....I would not use more than a 50 shot on a stock motor, which probably will not get you into the 13s
Old Oct 24, 2001 | 09:58 AM
Mike D's Avatar
Default Re: n2o or not!? (DragIIcivic)
what kind of engien do you have? Swap? Drag is right. n2o is saafe when used properly. Once installed take it to teh dyno and tune it right.
I think with the right tuning you could possibly run a 75 shot.
Old Oct 24, 2001 | 10:05 AM
WAFFLES's Avatar
Sorry I had to flame you for this one, but cams don't affect the compression.
But, I would say a high compression b18c or ls-b20/vtec will get you there
Old Oct 24, 2001 | 10:14 AM
Backyard Speical's Avatar
NOS is good and dragIIcivic is right. if you decide to use over 60 shot of NOS you're gonna need a fuel pump, and if you want really feel the NOS please don't get a dry system, you won't feel it as much as the wet setup.
Oh yeah what motor do you have in the EG? one of my friend has a 92 white EG justlike yours with bone stock LSD GSR hit 14.0 so close to a high 13s.
[Modified by Prodigy 2.2 EK, 9:34 PM 10/24/2001]
Old Oct 24, 2001 | 01:03 PM
mr2's Avatar
mr2
Default Re: n2o or not!? (Prodigy 2.2 EK)
im getting either a b16a, or a gsr motor.. the swap is coming before december rolls around.. sorry about the high compression cam comment
Old Oct 24, 2001 | 01:21 PM
the b16a with 80 shot you'll be good for the 13s. i know someone had a 94 hatch with a gsr and on top of that had a 100 shot direct port. he hit mid 12s. the gsr was bone stock...
have you ever thought about going prelude h22a motor in your hatch??? you'll be in the 13s no problem...
Old Oct 24, 2001 | 01:29 PM
Kamin's Avatar
yea with one hell of an understeer on the street if no supension mods.
Old Oct 24, 2001 | 01:38 PM
chad's Avatar
Moderator
nos on a b16 is nice.....even a dry setup!!
jamescb77
Apr 1, 2007 10:25 PM
D16zex
15
Dec 22, 2005 10:50 AM
slo_crx
Nov 5, 2004 04:02 PM
cw98typer
Feb 29, 2004 11:02 AM
NirVTEC
Feb 17, 2004 10:38 AM
