b16a OIL SQUITERS on b18c??? is this ok????
Sup all.... I just bought a JDM B18C block and one of the oil squiters is broken..... is it ok to use a b16a oil squiter to replace it??.... I compared them and they are slightly different. If somebody has done it here please let me know if you had any problems with it. Thanks!
Don't !! They are different and the crank are different as well. You may have a problem with the crank journals hitting the oil squirter at any directions
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Don't !! They are different and the crank are different as well. You may have a problem with the crank journals hitting the oil squirter at any directions
stan</TD></TR></TABLE>
Sup Stan! Thanks for letting me know.... can I just remove all the squiters and plug them with a bolt??? Does having oil squiters really a big diff.???? Thanks all
