b16a OIL SQUITERS on b18c??? is this ok????
Sup all.... I just bought a JDM B18C block and one of the oil squiters is broken..... is it ok to use a b16a oil squiter to replace it??.... I compared them and they are slightly different. If somebody has done it here please let me know if you had any problems with it. Thanks!
Re: b16a OIL SQUITERS on b18c??? is this ok???? (B18C1-Turbo)
Don't !! They are different and the crank are different as well. You may have a problem with the crank journals hitting the oil squirter at any directions
stan
stan
Re: b16a OIL SQUITERS on b18c??? is this ok???? (Willis)
damn i just bought a used set of b16a2 squirters that WERE going into a gsr block. the bolt should be the same though right?
Re: b16a OIL SQUITERS on b18c??? is this ok???? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Don't !! They are different and the crank are different as well. You may have a problem with the crank journals hitting the oil squirter at any directions
stan</TD></TR></TABLE>
Sup Stan! Thanks for letting me know.... can I just remove all the squiters and plug them with a bolt??? Does having oil squiters really a big diff.???? Thanks all
Re: b16a OIL SQUITERS on b18c??? is this ok???? (Burke)
I put my b18c oil squirters on my B16a block and no hitting problems here. Since they don't hit, are they still bad to use?
