P13 OBD1 on a 2000 Lude... will it work?
Old Mar 29, 2004 | 07:36 PM
shizty20's Avatar
Default P13 OBD1 on a 2000 Lude... will it work?
Im gonna do an auto SS > manual swap on my prelude. I got the tranny but I found an OBD1 p13 ecu and i think its from a 4th gen lude. Will I have any problems other than getting the right harness for it? Any help with this will be greatly appriciated. Thanx!
Old Mar 29, 2004 | 08:01 PM
Kal's Avatar
Kal
Default Re: P13 OBD1 on a 2000 Lude... will it work? (shizty20)
you gotta switch to other OBD I components also.. i believe they are the injectors and distributor.
Old Mar 29, 2004 | 08:05 PM
Sam1am26's Avatar
Default Re: P13 OBD1 on a 2000 Lude... will it work? (Kal)
A Skunk2 OBD2 to OBD1 Wiring Harness, a set of 345cc injectors with a resistor box, and an OBD1 Distributor is all you should need I believe...
Old Mar 29, 2004 | 08:32 PM
shizty20's Avatar
Default Re: P13 OBD1 on a 2000 Lude... will it work? (Sam1am26)
Whoa, i dint know I had to change all that, you guys think Il have any trouble with the immobilizer unit or can I have that ECU coded to work with it? Thanx.
Old Mar 29, 2004 | 08:34 PM
99spanishGT
Guest
Posts: n/a
i think it would be cheaper to get obd-2 ecu!
Old Mar 29, 2004 | 08:38 PM
shizty20's Avatar
Default Re: P13 OBD1 on a 2000 Lude... will it work? (spanishlude)
Damn, I already bought the ECU though. I dunno I may just put it on Ebay or something and get the OBD-II.
Old Mar 29, 2004 | 09:30 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">you gotta switch to other OBD I components also.. i believe they are the injectors and distributor.</TD></TR></TABLE>
Not true on the distributor. You would need the injectors. You will lose your immobilizer functionality, just so you know.
bvilleteggy62
Sep 20, 2007 06:09 PM
3rdgencrx
Mar 6, 2007 03:50 PM
Adam West
May 8, 2006 03:47 AM
C_I_V_I_C
Nov 5, 2003 05:26 PM
PhuckinHondas
Jul 30, 2002 08:06 PM
