Fast idle thermo valve is broken
My fast idle thermo valve sensor is broken i believe. I taped the holes up with a piece of duct take, but it came off. Im in need of a new one. i was thinking of just buying the whole throttle body with the whole valve attached off of ebay and just put it in. Will a JDM SIRG one fit or one off of a LS integra fit on my 94 gsr...or do i need a GSR specific one?
you can upgrade to a newer LS throttle body. Those doent have the FITV and your car will run fine.. or you can buy my FITV. it came off my 95 LS
can anyone else answer my question....do all integras have a idle control vavle...and are all integrs throttle bodys the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr »</TD></TR><TR><TD CLASS="quote">can anyone else answer my question....do all integras have a idle control vavle...and are all integrs throttle bodys the same?</TD></TR></TABLE>
Did you not read what i typed ?
No not all Integra Throttle Bodies are the same. You can use a TB with a FITV or without .. your integra will run fine and will not throw a CEL
ok sorry no didn't see it. My car isn't throwing a CEL its just idling really bad. I know its the sensor inside the fast idle thermo valve and just need to get a new one. So i don't really want to get a LS throttle body becuase i don't know if i am going to have troubling putting that on my GSR intake manifold and also if there is anything else involved in it. I actually just want to get the valve so i can switch the sensors out. You mentioned you had one. How much are you looking to get for it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr »</TD></TR><TR><TD CLASS="quote">ok sorry no didn't see it. My car isn't throwing a CEL its just idling really bad. I know its the sensor inside the fast idle thermo valve and just need to get a new one. So i don't really want to get a LS throttle body becuase i don't know if i am going to have troubling putting that on my GSR intake manifold and also if there is anything else involved in it. I actually just want to get the valve so i can switch the sensors out. You mentioned you had one. How much are you looking to get for it?</TD></TR></TABLE>
http://www.acuraparts247.com
i just looked it up on here.. and they sell it brand new for $60 go ahead and pick one up... it wouldnt be worth my time to sell you mine for $30
later
later
