Integra Governers
ive toped mine out at 150 at about 7500 rpms if i remember correctly,so i believe there is no governor in integras
Modified by xplanetearth420x at 12:34 AM 3/30/2004
USDM Integras Generation 3 do NOT have a governor. They are limited by power and engine speed.
JDM Gen 3 Integras DO have a governor.
I'm not sure about the previous generations, but I'm pretty sure they do. I believe they have the same limit as Civics do....around 120something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 plus 1 »</TD></TR><TR><TD CLASS="quote">My car doesnt have the ***** to do more than 132. With NOS it will
NOS at 132mph
</TD></TR></TABLE>NOS at 132mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline »</TD></TR><TR><TD CLASS="quote">if you put a turbo on an integra with just i/h/e and run it with low Psi levels is it still a danger to ur engine?</TD></TR></TABLE>
BAHAHAHAHHAHAHA. Sorry, but that quote is going in my signature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline »</TD></TR><TR><TD CLASS="quote">well sooooooory i don't know much about turbo, i'm just asking wut i've heard</TD></TR></TABLE>
I know I know....hehe. My bad. But everyone has a quote in their profile, I just wanted to fit in.
Anyway.....with turbo, you eliminate the intake and the header with the intercooler piping and turbo manifold respectively. And yes, you can put a turbo on a stock motor with no worries if the boost level is low and you have good tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline »</TD></TR><TR><TD CLASS="quote">So you could have a blow off valve and all that with your turbo, even with low levels of boosT?</TD></TR></TABLE>
Yes sir. A blow off valve just reduces the chance of compressor surge where all that pressure is suddenly stopped at the throttle plate when it closes.....which then goes back to the turbo. 5-10psi won't do too much damage, but it's possible.
i just like the sound of the blow off valve thats why im asking, lol. Eventually ill beef up my engine enough to have high Psi levels, but until then...just the knowing fact i have turbo is fine lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">USDM Integras Generation 3 do NOT have a governor. They are limited by power and engine speed.
automatic G3 integras DO have a governor, manuals do not
</TD></TR></TABLE> HAH!
This ones going on mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_ej1 »</TD></TR><TR><TD CLASS="quote">
automatic G3 integras DO have a governor, manuals do not</TD></TR></TABLE>
You sure about that? Mine didn't.
My 1997 LS was an automatic, I swapped it over to the 5-speed with the SAME automatic ECU.
I haven't encountered a limit when it was automatic....unless it's higher than 135mph. Using the same ECU with my built turbo setup and after the 5-speed swap, unless the limit is over 155mph, then it doesn't have a governor.
From: That's the wrong tone... I'm Skunk2 certified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ru2slo »</TD></TR><TR><TD CLASS="quote"> HAH!
This ones going on mine.</TD></TR></TABLE>
dammit, i wanted that one...
This ones going on mine.</TD></TR></TABLE>dammit, i wanted that one...
Mr. Softee
Nov 9, 2003 03:10 PM
