mods effecting Redline?
Old Mar 29, 2004 | 02:56 PM
lastpunkinline's Avatar
Default mods effecting Redline?
I was just wondering, does adding mods like i/h/e just add horsepower and torque or does it effect how much more you can redline also?
Old Mar 29, 2004 | 03:01 PM
xSCTYGx's Avatar
Default Re: mods effecting Redline? (lastpunkinline)
the only way to change where you redline is by doing something to your ECU...for example, different ECU, chip, etc...
Default Re: mods effecting Redline? (2Gen91Teg)
Where can you buy chips?
Old Mar 29, 2004 | 03:18 PM
Senbonzakura's Avatar
get someone to chip it for you. Go check out the classified section.
Old Mar 29, 2004 | 03:20 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote">the only way to change where you redline is by doing something to your ECU...for example, different ECU, chip, etc...</TD></TR></TABLE> also, even if you up your redline via ecu mods, you need to upgrade your valvetrain in order to handle the higher redline. ( ie different valvesprings and retainers)
Old Mar 29, 2004 | 03:29 PM
xplanetearth420x's Avatar
Default Re: mods effecting Redline? (Threatcon13)
get hondata to chip it
Old Mar 29, 2004 | 03:48 PM
smallttocs's Avatar
Default Re: mods effecting Redline? (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">get hondata to chip it</TD></TR></TABLE>
yeah if you want to spend $600
do it yourself... search on how to do it or find someone who will.
as for your question, just i/h/e will let your motor breathe better but your valve train is still stock. you need to up grade that before you can raise the red line at all.
Old Mar 29, 2004 | 03:52 PM
Default Re: mods effecting Redline? (smallttocs)
How much do valve train's usually go for?
Old Mar 29, 2004 | 03:53 PM
xSCTYGx's Avatar
check out my avatar, it provides all the info you will need to get started.
Old Mar 29, 2004 | 05:24 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I/H/E do not add horsepower or torque. It only frees up power that was restricted before due to the relatively restrictive intake, exhaust manifold and exhaust.
And there is absolutely no point in revving higher unless you do mods that will actually make power up there. Stock GS-R's fall on their faces not too far past 7K rpm, so revving higher would probably make you slower w/ an otherwise stock engine (assuming the valvetrain could handle it). You would need other things to raise the power in the upper RPM range like hotter cams, adjustable cam gears, engine management, with everything tuned to work together on a dyno.
NHBP_Civic
Honda Civic (2006 - 2015)
23
Mar 10, 2007 04:02 PM
JUNcr-x
Jun 9, 2006 06:49 AM
JrCRXHF
Jul 12, 2005 09:16 PM
Ty.
Jun 17, 2005 06:03 PM
94dxt
Dec 2, 2003 09:55 PM
