people with swaps, were you able to retain your AC?
Old Mar 29, 2004 | 01:19 PM
jaydub's Avatar
Default people with swaps, were you able to retain your AC?
I'm piecing together some information and I'm curious if those of you with swaps were able to retain your air conditioner. Reason I ask is because no AC in Vegas sucks ***.
thanks (and yes I searched).
Old Mar 29, 2004 | 01:34 PM
REDBARON's Avatar
Default Re: people with swaps, were you able to retain your AC? (jaydub)
I have a 91 CRX HF and I retained my A/C when I went to a B16.
warchild69's Avatar
unless you go to a H-22 then you can use A/C with all of them.... now it may not be the bracket that comes with the new engine..... some will work though.... and i have heard of people changing their compressor for a Del-Sol one or the Dsol bracket.... anyway you can make it work.... i could have easy with my ZC but i chose not to and to trash the whole system....... good luck
Old Mar 29, 2004 | 01:35 PM
jaydub's Avatar
Default Re: people with swaps, were you able to retain your AC? (REDBARON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 CRX HF and I retained my A/C when I went to a B16.</TD></TR></TABLE>
excellent, this is exactly what I was considering. Did you run into any issues, and did your car come with it originally?
Old Mar 29, 2004 | 02:09 PM
Adam.C's Avatar
hasport makes an a/c bracket for a b16 swap into a crx. I think it runs about $160 or so.
Old Mar 29, 2004 | 02:12 PM
jaydub's Avatar
awesome.
Thanks. you guys were a big help.
Old Mar 29, 2004 | 02:20 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydub &raquo;</TD></TR><TR><TD CLASS="quote">excellent, this is exactly what I was considering. Did you run into any issues, and did your car come with it originally?</TD></TR></TABLE>
I swapped a 95 B18b into my HF. Used the Hasport mount and AC mount. No probs at all. My car came with AC and during the swap, I did not undo any of the AC lines. Just unbolt the compressor and zip tie it to the frame. During re-install of the new engine, assemble the AC mount before dropping in and just bolt up the compressor. No recharge.
HTH
chris
Old Mar 29, 2004 | 02:34 PM
jaydub's Avatar
very helpful, thanks!
Old Mar 29, 2004 | 02:41 PM
spaceman's Avatar
i got a complete a/c system from a jdm b16 you can have,im in arizona come get it
Old Mar 29, 2004 | 02:42 PM
jaydub's Avatar
Default Re: people with swaps, were you able to retain your AC? (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">i got a complete a/c system from a jdm b16 you can have,im in arizona come get it</TD></TR></TABLE>
haha i appreciate the offer, but I don't even have a CRX yet. I am currently in "convincing the wife" stage.
Old Mar 29, 2004 | 02:43 PM
michael O's Avatar
I'm having some trouble retaining my ac because I put a JG header onto my b16crx. The header doesn't clear the front crossmember or the AC fan. Btw I'm using the hasport mount kit.
Old Mar 29, 2004 | 02:47 PM
pyro_freak8's Avatar
i swapped a ZC into my 91 CRX HF and the compressor brackets bolted up just fine....ac runs great
Old Mar 29, 2004 | 02:49 PM
spaceman's Avatar
Default Re: people with swaps, were you able to retain your AC? (michaelOlson)
your gonna have to do some modifying to that crossmember and then you can go with one of those half size radiators from a newer vehicle and then hook up the a/c
Old Mar 29, 2004 | 04:16 PM
virginia_dude's Avatar
B16A1 one in a 89 DX hatch, kept mine with a Hasport bracket.
Old Mar 29, 2004 | 08:40 PM
urquidezj's Avatar
i used the stock ac bracket that came with it and it stayed in there fine. one problem though, when i am driving and i am gonna reach a stop, i let it brake with the engine and the ac compresor hits the front crossmember and it vibrates the whole car. i want to get the hasport ac bracket but i dotn know if it will work with the HCP mount kit i got for it. does anybody know?
Old Mar 29, 2004 | 08:54 PM
kevinoneill's Avatar
Yeah i'm pretty sure you can have A/C with most of the engine swaps it just takes up room some people need for other stuff. i live in florida and no AC for me, i just roll down the window's works the same in my opinion.
Old Mar 29, 2004 | 11:42 PM
Fobtions's Avatar
Default Re: people with swaps, were you able to retain your AC? (issues4)
as long as u use the original sized compressor off the sohc it will work. If u try to use the one that most b16 swaps come with, its too big.
Old Mar 30, 2004 | 05:21 AM
jaydub's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues4 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i'm pretty sure you can have A/C with most of the engine swaps it just takes up room some people need for other stuff. i live in florida and no AC for me, i just roll down the window's works the same in my opinion.</TD></TR></TABLE>
hehe rolling the windows down in 115 degree heat = hair dryer.
dr_latino999's Avatar
You can retain it by using the bracket, but you may have clearance issues due to the fact that the B-Series engine were designed for a larger bay in mind. Also, the compressor takes up space that you might need for other projects down the road, eg. FI.
I roll with the windows down too, it just sucks when it is A) Raining but humid like crazy & B) Stuck in gridlock traffic.
Old Mar 30, 2004 | 06:34 AM
jaydub's Avatar
yeah i'm somewhat "spoiled" with Las Vegas heat. I had gone to visit a buddy of mine in Washington, DC and we thought it'd be a good idea to go out walking around in Georgetown in 96 degree heat with 99% humidity. I thought I was going to die. :D
Old Mar 30, 2004 | 07:29 AM
spaceman's Avatar
Default Re: people with swaps, were you able to retain your AC? (dr_latino999)
true,but the a/c system is ez to install/uninstall if you know what your doing
Old Mar 30, 2004 | 07:39 AM
jaydub's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">true,but the a/c system is ez to install/uninstall if you know what your doing</TD></TR></TABLE>
That's a good point.
Old Mar 30, 2004 | 07:52 AM
Driven's Avatar
i had to make AC...
Old Mar 30, 2004 | 08:01 AM
jaydub's Avatar
Default Re: people with swaps, were you able to retain your AC? (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">i had to make AC...
haha sweet.
ef-hatchcrap
19
Feb 19, 2009 11:37 AM
socalibur
May 31, 2006 04:41 AM
RaysBoomBoomLude
27
Aug 24, 2005 07:54 AM
forever slow EG6
Jun 12, 2005 03:59 PM
Papichulo1767
Jul 23, 2004 03:29 PM
