help me i fear the worse
Old Mar 29, 2004 | 07:59 AM
h23 milano red's Avatar
From: south grand prairie aka the pits of saburbian hell, tx, usa
Default help me i fear the worse
So im droping my friend off friday night and i notice that when im in gear around 2000 3000 rpm that my engine started to bog down but once i give it some more gas i was cool so the next day were going to the h-t meet in Richardson and half way there it wouldn't let me go past 4000 rpm if i try then i would loose power . in the mean time my tach needle was jumping all crazy and on the way back it would only let me go to 3200 rpm so as soon as i got home i parked it and i plan on putting it in the shop when I get out of school today
Old Mar 29, 2004 | 08:04 AM
prelittlelude's Avatar
Default Re: help me i fear the worse (h23 milano red)
does the car idle normal? had you noticed ANYTHING out of the ordinary befor ethis started to happen, is the check engine light on? is there any noise coming from the engine other than a bogging? how many miles? timing belt been done?
Old Mar 29, 2004 | 08:06 AM
AndyD's Avatar
Check to see if your catalytic converter is bad. Also, check your spark plugs and spark plug wires.
Old Mar 29, 2004 | 08:08 AM
PirateMcFred's Avatar
How many miles on your engine? What mods including to the ECU if any? How high do you rev it? Look at the oil on the dip-stick. If it shimmers like it has metal flakes in it then you have a spun bearing.
the Pirate
Old Mar 29, 2004 | 08:22 AM
stareatsun's Avatar
Default Re: help me i fear the worse (PirateMcFred)
check oil. could be a pressure prob. vacuum lines ok? oil pressure ok?
Old Mar 29, 2004 | 08:23 AM
my check engine light has been on for the past 3 months but my car has been running fine i just thought it was some thing rong wit the wires or something, my car was broken into in september and they riped my engine harness out but i had it fixed
Old Mar 29, 2004 | 08:24 AM
it idles normal i only have a intake short ram and nothing to the ecu
Old Mar 29, 2004 | 08:39 AM
Default Re: (h23 milano red)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23 milano red &raquo;</TD></TR><TR><TD CLASS="quote">my check engine light has been on for the past 3 months but my car has been running fine i just thought it was some thing rong wit the wires or something, my car was broken into in september and they riped my engine harness out but i had it fixed </TD></TR></TABLE>
well there is where you start, that little wiring problem you had probably just turned into a BIG problem
Old Mar 29, 2004 | 02:28 PM
what are your engine codes? Figure those out and you will probably fix your problem.
the Pirate
Old Mar 29, 2004 | 02:33 PM
Crate's Avatar
no weird noises from the engine? just strange idle and loss of power? no ticking, clanking or anything like that?
Old Mar 29, 2004 | 03:01 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23 milano red &raquo;</TD></TR><TR><TD CLASS="quote">my check engine light has been on for the past 3 months but my car has been running fine </TD></TR></TABLE>
way to go on that one...didn't even check the codes...
Old Mar 29, 2004 | 03:14 PM
yohan's Avatar
Sorry, I have to bash you about driving a car for 3months with a ** WARNING ** light on ...especially one that so obviously means theres a potential problem with the most signifigant part of your car , the engine! ... Would you let an oil light run for 3months?
Thats car abuse mang .. tsk tsk ..
anyways, go get a paper clip, bend it into a U shape, pull the service connector from behind the stereo (easy to reach driver side by the gas pedal) its a little clip with 2 wires plugged into an empty connector to hold it ..
put the paper clip in there, it'll blink a series of long and short ,tell us how many long/short ... there can be multiple codes and each will be 2 digit so get a pen/paper and write it down until it starts to repeat itself.
in the meantime, open up the distributor cap and tell us if there is a lot of dust inside .. could be your distributor is toast.
Old Mar 29, 2004 | 03:46 PM
ive riped all apart my pasenger side carpet looking 4 the ecu and couldnt find it niether could my friend its in the shop now so gusse ill here it from them
thanks for the in out guys and thanks for the bashing
Old Mar 29, 2004 | 04:14 PM
satan_srv's Avatar
they ecu is under the kick plate.
Sorry man but getting your wire harness 'fixed' and having an engine code is not 'fixed'
Old Mar 29, 2004 | 04:35 PM
JG Luder's Avatar
Default Re: (satan_srv)
I think I might agree with the clogged cat.
It would throw a code, and it would cause the car to run badly.
And staring at a CEL for three months... My God, that's bad. As punishment you must give me your Prelude and drive a Civic.
Old Mar 30, 2004 | 07:59 AM
i know, its hard to get it checked out when you dont have a job and your parents dont hellp you wit **** i know its not a excuse but i wouldnt mind driving a crx si for a lil bit or a ef hatch
Old Mar 30, 2004 | 08:05 AM
confusion5's Avatar
Default Re: (Lone Luder)
I know this is off the subject of my lude' but my camaro had this same problem and it was along the lines of throwing a code and not having a sensor connected, if that helps at all
Old Mar 31, 2004 | 11:08 AM
yohan's Avatar
I have to agree with lone luder ... thats a really harsh insult for a prelude enthusiast but ... I think its fitting for having an engine code and when its free and easy to check (and you do have the resources because you're here) .... yea ... best of luck.
Old Apr 1, 2004 | 07:54 AM
ok so i get my car back today and there was a group of wiers next to the intake and valve cover were out of the socket and i think some thing was wrong with the egr valve i think thats what its called corect me if im wrong
Old Apr 1, 2004 | 08:20 AM
AndyGCT's Avatar
dude you know what works for your check engine light, unplug the negative power cable for like 15-20 minutes, it will reset the ECU, sometimes i think it goes off for petty ****, but if it goes on within an hour after you reset it, just go get it checked...
Also, for the engine probs, it might not get over 4K rpms cuz youre plugs or wires are shot...
Old Apr 1, 2004 | 10:51 AM
JDMSloLude's Avatar
Default Re: (AndyGCT)
It also can be your distributor. Thats pretty much the same crap that happened to my when my distributor died. Best advice is check your codes!! You will be able to tell for sure then. I just leave that blue wiring dangling since I am checking codes every week Good luck, keep us updated.
Old Apr 1, 2004 | 12:28 PM
TurboSam's Avatar
Default Re: help me i fear the worse (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if your catalytic converter is bad. </TD></TR></TABLE>
whats that?
Old Apr 9, 2004 | 02:22 PM
ok so last night i put new spark plugs and a new rotor and my car turned on to day but still wont go past 3500 rpm i my cuz who has a shop check out the ecu and he said he fixed it but i gusse he didnt so now im going to wate till monday and put it in another shop that i know about in arlington tx call acruurate car care so im pissed and stressed cuz i dont have a jobb and my parents are as hole so i will hit every 1 back up mon or tusday
Old Apr 9, 2004 | 04:38 PM
Shakes's Avatar
space cadet
Default Re: help me i fear the worse (Turbo Sam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">
whats that?</TD></TR></TABLE>
its this thing that causes back pressure. the car comes with one from the factory but silly people leave it on there for some reason
Old Apr 9, 2004 | 04:49 PM
fastludeh22's Avatar
not sure, i think i had one once...but i doubt it
Rotting Prelude
Aug 22, 2017 12:32 AM
ShamArtist
35
Apr 5, 2017 05:59 PM
kyosuke714
Oct 15, 2005 07:56 AM
lococoin
Nov 23, 2003 04:18 PM
joeg26er
Jan 29, 2003 08:40 AM
