94 Accord ABS error code 4-4
On my '95 Integra, code 4-4 is right-rear wheel sensor. I don't know what years/cars have the same list of ABS codes... Good source is a Helm shop manual; that's a good thing to have if you wanna fix it yourself.
Did someone say ABS?
http://www.bba-reman.com/hondaalb2computer.htm
Code / Fault
1 Hydraulic pump motor over-run (contact BBA)
1-2 Hydraulic pump motor (contact BBA)
1-3 High pressure leak (possibly modulator)
1-4 Pressure switch (contact BBA)
1-8 Pressure accumulator
2-1 Handbrake warning lamp switch circuit faulty
3-1 Right hand front rotor damage
3-2 Left hand front rotor damage
3-4 Right hand rear rotor damage
3-8 Left hand rear rotor damage
3-12 Different tyre sizes fitted
4-1 Right hand front wheel sensor
4-2 Left hand front wheel sensor
4-4 Right hand rear wheel sensor
4-8 Left hand rear wheel sensor
5-4 Right hand rear wheel lock
5-8 Left hand rear wheel lock
6-1 Front fail safe relay
6-4 Rear fail safe relay
7-1 Right hand front modulator solenoid valve
7-2 Left hand front modulator solenoid valve
8-1 ABS operation fault
8-2 Electronic control unit (ECU) fault
8-4 Electronic control unit (ECU) - internal circuit fault
Code / Fault
thanks a bunch. yes it is a faulty right rear wheel speed sensor. after searching online i actually found a cool site with a bunch of the actual honda/acura shop manuals in pdf format (these are the big 1500+ page books the dealers use.) now if only i could find a wheel sensor for less than $100.
you might be able to pull a used one from a wrecked car for a few bucks...if you cross-check the part-numbers you might be able to use 90-97 (or something like that).
i've replaced the sensor with a used one that checked okay with the voltometer (ohms were at about 800+ which is in the 600-900 acceptable range per manual). still have the same error code showing up. i've cleaned it. same problem. cleaned pulser. same problem. pulled out the fuses (along with some hair). still the same problem. damn you DTC 4-4 "Right-rear Wheel Sensor"...my ***! help me if you can.
Thanks,
Scott
Thanks,
Scott
