Knock sensor wire came off harness
Old Mar 28, 2004 | 07:25 PM
quiksheit's Avatar
Default Knock sensor wire came off harness
Just did a headgasket and ended up ripping the knock sensor harness off of the wire. (It's the green harness right by the oil filter) Then i got a CEL 23
What i gather from searching or personal experience:
It's shielded wire
The harness is not sold separately
Tried to reattach the wire and use nonshielded wire to extend and reattach it. NOPE
Cant find shielded wire without ordering
I dont really care to get a new ECU w/o the KS
looking for a realtively cheap fix
Simply grounding it doesnt always work to fool the ECU
Using a resistor might not work either. Mixed opinions
What else can i try?
Can i simply replace the whole wire? HOw?
TIA
Old Mar 29, 2004 | 08:54 AM
Civiclx's Avatar
Default Re: Knock sensor wire came off harness (quiksheit)
bump for this, i have the same problem yo
Old Mar 29, 2004 | 10:23 AM
Civiclx's Avatar
ttt
Old Mar 29, 2004 | 02:25 PM
Civiclx's Avatar
bump, where does the knock sensor wire ground? can i just ground it on the chassis somewhere?
Old Mar 29, 2004 | 03:00 PM
quiksheit's Avatar
See thats the thing. I dont see any ground...but ppl do say its shielded
Old Mar 29, 2004 | 05:53 PM
irev210's Avatar
Default Re: (quiksheit)
The wire is only sheilded for about 6 inches then it turns into regular wire.
You can rip the sheilding off, it really serves no purpose.
All the hybrid swaps that I do when I add the knock sensor wire to the wiring loom I never actually reuse that 6 inch part that is sheilded, I cut and slide the shield off, it just gets in the way.
I would just cut and sodier a new wire/plug on there and be done with it
Old Mar 29, 2004 | 06:16 PM
Civiclx's Avatar
Default Re: (irev210)
so just run the wire from the ecu pin stright to the knock sensor and call it a day?
PLMAC
Oct 18, 2008 10:12 AM
EG2_AP1_AE86
May 28, 2008 10:21 AM
som3on3_10
May 6, 2005 01:12 PM
SleeprCivic
May 16, 2003 05:54 PM
