Anyone, Anyone HELP PLEASE
Old Mar 28, 2004 | 07:14 PM
SleepyHF's Avatar
Default Anyone, Anyone HELP PLEASE
Just finished putting back on my d16z6 head after replacing ALL the valves in it cause they all were bent when the timing jumped. Put everything bac together and started the car, it idles all weird and bogs down and dies if i dont push the gas. Also my check engine light is on the dash. This NEVER was on before the head was pulled off and the valves were replaced and head put back on. The check engine light never came on before. I am running the HF ecu. ANYONE please help. what can i check or look for. Why is it dying if i dont push the gas.
PS. Feels like VTEC is always engaged but vtec isn't even hooked up....doesn't have power
Old Mar 30, 2004 | 04:26 PM
SleepyHF's Avatar
Default Re: Anyone, Anyone HELP PLEASE (ConfusedHF)
bump
Old Mar 30, 2004 | 04:29 PM
spaceman's Avatar
are you sure everything was put back correctly?did you miss any wires/grounds
Old Mar 30, 2004 | 04:35 PM
SleepyHF's Avatar
Default Re: Anyone, Anyone HELP PLEASE (spaceman)
SOLVED....the ECU was throwing CEL 5 ...MAP sensor..changed it out and now its perrrrfeeeect...thanks
mazEK
11
Jan 11, 2007 06:29 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
Jamez
May 2, 2004 02:33 PM
-[95cxhatch]-
Aug 18, 2003 08:01 AM
