Need yall's Help, 98% done w/ swap and Cant get wheels To turn!!
Old Mar 28, 2004 | 11:39 AM
DC 2's Avatar
Default Need yall's Help, 98% done w/ swap and Cant get wheels To turn!!
Fixed: Problem was the Dust seals
88 crx b16 swap, Mid-way through the swap I noticed the front wheels would not rotate. I presumed the front calipers were locked on, today I removed them to find out its not the problem. Both Driver and passenger side hubs are frozen. I had the car in the air for a week, and worked fine before . I dont believe its the tranny b/c I remeber turning the axel when installing them. Both wont budge at all, not even a mm. I thought the axel nuts may be too tight, loosened them and still nothing. Any IDeas? Im stuck and this is the only thing keeping me from driving the car.
Modified by EH3B18B at 11:55 PM 3/28/2004
Old Mar 28, 2004 | 01:08 PM
Kal's Avatar
Kal
Default Re: Need yall's Help, 98% done w/ swap and Cant get wheels To turn!! (EH3B18B)
kinda very dumb question, but is the car in gear?
Old Mar 28, 2004 | 01:18 PM
simple4012's Avatar
New User
Default Re: Need yall's Help, 98% done w/ swap and Cant get wheels To turn!! (Kal)
I am already guessing what is happening.
The car is a DX and the axles fit but the car wont move.
get some si hubs y0!
Old Mar 28, 2004 | 01:30 PM
DC 2's Avatar
Default Re: Need yall's Help, 98% done w/ swap and Cant get wheels To turn!! (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">I am already guessing what is happening.
get some si hubs y0!</TD></TR></TABLE>
The car is an Si and its in Neutral, someone mentioned the dust seals on the knuckles. I removed what I thought was the dust seal" little rubber rings on the out c/v's. Is the Dust seal a big metal ring??
Old Mar 28, 2004 | 01:44 PM
SprayinCX's Avatar
well here could be a thoguht.
with the axle out will the hub turn? if yes then it will be the axle itself, since you said you can turn the tranny by hand.
RATCH
Apr 2, 2008 03:48 PM
Prod
25
Oct 30, 2005 10:34 AM
naptownrex
Feb 6, 2005 02:28 PM
DC 2
Mar 28, 2004 02:20 PM
roadawg
10
Dec 25, 2003 06:09 AM
