May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim??
Old Mar 28, 2004 | 11:39 AM
Acura_I-RS's Avatar
Default May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim??
some one is telling me that is how the scale works, and im kinda hinking he is wrong.. please explain the differences so i can back my opinion up!!! thanks
Old Mar 28, 2004 | 11:58 AM
Mase's Avatar
Default Re: May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim?? (Acura_I-RS)
57 is larger
Old Mar 28, 2004 | 12:07 PM
Acura_I-RS's Avatar
Default Re: May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim?? (Mase)
how is it measured, do you know?? i want something to back it up
Old Mar 28, 2004 | 12:13 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_I-RS &raquo;</TD></TR><TR><TD CLASS="quote">how is it measured, do you know?? i want something to back it up
diameter in mm of the compressor wheel, i believe.
Old Mar 28, 2004 | 02:19 PM
ndogg's Avatar
Default Re: May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim?? (envision2teg)
i think it is actually a ratio of the inside to outside diameter of the wheel or some ****.
Old Mar 28, 2004 | 02:27 PM
RyanEJ8's Avatar
The compressor trim is the squared ratio of the smaller diameter divided by the larger diameter multiplied by 100 of the compressor wheel. The smaller diameter of the wheel is the inducer, and the larger diameter of the wheel is the exducer.
Old Mar 28, 2004 | 02:34 PM
Del's Avatar
Del
Default Re: May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim?? (RyanCivic2000)
inducer^2/exducer^2 x 100
its just a ratio, a .50 trim can be bigger than a .57
Old Mar 28, 2004 | 02:35 PM
Del's Avatar
Del
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">The compressor trim is the squared ratio of the smaller diameter divided by the larger diameter multiplied by 100 of the compressor wheel. The smaller diameter of the wheel is the inducer, and the larger diameter of the wheel is the exducer. </TD></TR></TABLE>
dammit you beat me
Old Mar 28, 2004 | 04:27 PM
Acura_I-RS's Avatar
Default Re: May Be a Stupid Question, but is a to4e 50 trim bigger than a 57 trim?? (Del)
ok, im starting to catch on, so all it is is the relation of the smaller inducer, in comparison to the larger exducer, so in a way the ratio of the air it takes in compared to what it actually uses?
Old Mar 28, 2004 | 04:48 PM
Del's Avatar
Del
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_I-RS &raquo;</TD></TR><TR><TD CLASS="quote">ok, im starting to catch on, so all it is is the relation of the smaller inducer, in comparison to the larger exducer, so in a way the ratio of the air it takes in compared to what it actually uses?</TD></TR></TABLE>
yes in a sense... it isnt in relation of a smaller inducer, its in relation to both the inducer and exducer.....
Old Mar 28, 2004 | 05:20 PM
Acura_I-RS's Avatar
yes, that is basically what i stated
xero_xero
May 4, 2010 08:05 PM
Dasanib20T
Oct 16, 2008 12:40 AM
twkdCD595
Aug 3, 2007 09:19 AM
thizboii
Feb 11, 2007 08:34 PM
alexsracing
Aug 21, 2005 08:44 AM
