how much boost from supercharger on a stock d16a6
hi im thinking about picking up a jackson racing supercharger and i would like to know how much boost i can run on a d16a6 with completly stock internals. and how much horspower could i produce???? thaks guys
Modified by darkcrx at 7:26 PM 3/28/2004
on the d16's the conecting rods are small and there known to break pritty easy even at 6lbs of boost they mite still break just so u dont put 1,000$ or more for a supercharger and risk blowing ur motor i would spend that money on building the motor with good 9:1 compression pistons and sone egal h beam rods then i will be able to have more boost than 6 i wouldnt recomend anymore than 6 lbs on a stock d16 on a daily driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick90hatch »</TD></TR><TR><TD CLASS="quote">on the d16's the conecting rods are small and there known to break pritty easy even at 6lbs of boost they mite still break just so u dont put 1,000$ or more for a supercharger and risk blowing ur motor i would spend that money on building the motor with good 9:1 compression pistons and sone egal h beam rods then i will be able to have more boost than 6 i wouldnt recomend anymore than 6 lbs on a stock d16 on a daily driver</TD></TR></TABLE>
Don't listen to a closed minded, unfounded opinion such as this.
You can safely boost the 6 or 8 psi w/o problems on the stock block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough »</TD></TR><TR><TD CLASS="quote">
You can safely boost the 6 or 8 psi w/o problems on the stock block.</TD></TR></TABLE>
with good tunning...
