finally got the koni yellows sp3's installed on the 00 gsr 4 dr
Old Mar 27, 2004 | 04:33 PM
greenteg2k00's Avatar
Default finally got the koni yellows sp3's installed on the 00 gsr 4 dr
its been a long day,finally got the koni yellows installed on the 2000 gsr, with neuspeed race springs, great handling guys, thanks for your help, just one more question do i need a alignment i just put on the koni shocks,alignment was done before when neuspeed race was installed a while back with stock shocks,how should i set the rears
Old Mar 27, 2004 | 07:33 PM
Cova85's Avatar
Default Re: finally got the koni yellows sp3's installed on the 00 gsr 4 dr (greenteg2k00)
What i have been reading around here you should.
But I have to ask you how low is it, and how big is the gap?? I am thinking about the same setup I am set on Koni Yellows but still not sure wich springs to use.
If you could get some pictures
Old Mar 27, 2004 | 07:57 PM
Default Re: finally got the koni yellows sp3's installed on the 00 gsr 4 dr (Cova85)
is it basically no gap to tell you truth but whats wrong with neuspeed race, it rides fine especially now with koni yellows it just sits low and when i go over speed bumps i don t even have to angle it,nothing really scrapes neuspeed race springs is a good choice
verycleanhatch
Suspension & Brakes
Oct 10, 2007 03:07 PM
pubes2942
Suspension & Brakes
Jan 2, 2007 11:09 AM
bonta-kun
Sep 4, 2004 09:39 PM
taytay333
Nov 8, 2001 09:22 AM
