Swap done. Car starts, but wont idle at all!! It shuts off. PLEASE HELP!!
The car starts and dies. I can keep it running if I give it gas. All the sensors are plugged in. The only CEL I'm throwing is a 10. Thats intake temp sensor. That would'nt cause this problem though. When I did the timing everything was TDC and perfect. If I hold the car at 800 RPM (Idle Spped) the timing is perfect with the light. What the **** is causing this problem????!!!????!?!?! I reset the ECU and everything.
Someone help please!
My SETUP:
D15Z1 Block
D16Z6 Head
D16Y8 Head Gasket
91 Si Tranny
PM6 ECU
My SETUP:
D15Z1 Block
D16Z6 Head
D16Y8 Head Gasket
91 Si Tranny
PM6 ECU
It was a vacuum leak. I'm using the Z6 manifold with the 91 Si vacuum system. Can I eliminate any hoses or those canisters on the back of the fire wall and re-run my vacuum lines to my intake manifold?
Modified by JSPECHB at 11:12 PM 3/27/2004
pearl
25
Oct 4, 2005 10:34 AM
