t3 compressor identification help
Old Mar 26, 2004 | 10:45 PM
XDEep's Avatar
Default t3 compressor identification help
mine is on the right. the numbers on the compressor were grinded off for some reason. all i know is the compressor wheel has a 46mm inducer/60mm exducer (58.7trim?). with my measurements, the AR for it is .36 which doesnt seem right. what does it look like to you?
the turbine housing is labeled with a .63AR. on the turbine wheel i measured a 48mm inducer/58mm exducer. how do you calculate the trim for that? i get a whole number if i do (exducer^2)/(inducer^2) and 68 trim if i inverse it.
Old Mar 26, 2004 | 11:01 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: t3 compressor identification help (XDEep)
did u take off the compressor cover to measure ? as well as the exhaust housing to measure ? if u did i have no idea otherwise i think u might have measured wrong
Old Mar 26, 2004 | 11:37 PM
XDEep's Avatar
Default Re: t3 compressor identification help (SIXTYdashONE)
to measure the wheels ya i took the housings off to get to the exducers. for the a/r's no.
EK k kay
Mar 3, 2006 07:24 PM
89dxhunchback
Aug 8, 2005 07:08 AM
Ri5e
Sep 9, 2004 03:52 PM
Zero_son
Mar 5, 2003 08:12 AM
Stock@$$GSR
Apr 18, 2002 06:22 AM
