h22 turbo timing
i finally got all my stuff, situation is i can't get it tuned untill the end of april, i'm running the hack with 450s, and using the p30 out of my del sol vtec. i'm tryin to get ahold of a wideband to tune it for now, but what should i do about timing, i don't understand where people are getting these degrees from, i've got a light, and my motor is in time, but how should i retard it, and how much
oh i forgot, the reason i want to use the wide band is because i have the vafc set at -10 took it around the block and the plugs are still grey, should i just keep richining it up or is there an easire way to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">?? i just want to retard it like 3 degrees, how do i know how many degrees i'm moving</TD></TR></TABLE>
are you using a timing light?
3 deg retarded at the distributor is gonna make the car run like Poo probably when you are off boost, but better safe than sorry..
holy **** man, this is from like 2 years ago...i had a cheap *** light at the time that wasn't a dial by degree style.
but thats all long sence gone, bigger turbo, aem ems, etc.....
